Just bought a 94 z28 it was a police car does mean anything?
Old Jan 22, 2010 | 11:22 PM
  #16
Wild Willy's Avatar
GM lists these RPO's for headlight flashers, at this time I cannot say if they were offered on the Camaro, but definitely there were factory wig-wags:
6J2 WIRING PROVISIONS, HEADLIGHT FLASHER AND GRILLE
6J3 WIRING PROVISIONS, HEADLIGHT FLASHER, GRILLE LIGHTS
6J4 WIRING PROVISIONS, HORN/SIREN CIRCUIT
the power steering option was
V12 COOLING SYSTEM, POWER STEERING, FLUID
Old Jan 22, 2010 | 11:30 PM
  #17
Wild Willy's Avatar
Old Jan 23, 2010 | 09:30 AM
  #18
Originally Posted by Wild *****
Admittedly, not much credible information available any more- lots of people repeating half truths- though, on this website, I found a GM publication quoted:
http://www.conceptcarz.com/vehicle/z...et-camaro.aspx
"...Camaro Special Service Package (SEO B4C). Police fleets can order a Special Service Package on the 1996 Camaro. First introduced on the 1991 Camaro RS, this package has become popular for highway and interstate traffic control. The B4C police package includes:
5.7 Liter LTI V8
6-speed manual or 4-speed electronically controlled automatic transmission
Single exhaust and converter with dual tailpipes
Performance suspension
16' aluminum wheels
P245/50ZR-16 speed-rated blackwall tires
4-wheel vented anti-lock disc brakes
3.23:1 limited slip rear axle (automatic transmission)
3.42:1 limited slip rear axle (manual transmission)
Transmission oil cooler (automatic transmission only)
140-amp alternator
525-CCA battery
Air conditioning
150-mph speedometer.
Source - GM Corporation..."
This is pretty accurate for the model year specified- the LT1 B4C's had a larger alternator than the LS1's got- typically the used Goodyear GS-c tires that were pricey and didn't last all that well, but were speed-rated.
Again, these are all the standard Z equipped parts. We aren't comparing LT1 to LS1 alternators.
Perhaps, but I have the Special Service flyers for the LT1 years and they don't mention these items. I thought it was the LS1 that had the power steering option as you described?
There was a guy on the board a few months ago that posted his actual build sheet for his 1996 B4C. None of those options you list above were on it.
Old Jan 23, 2010 | 10:47 AM
  #19
GS-C's were the standard tire on the early years, on ALL cars with the "QLC" Z-rated tire option. My 94 Formula had them from the factory, I replaced them at 20,000 miles and they still had more than 1/2 the tread left on them. I replaced them with 275/40-17 GS-C's, and took those off after they had 45,000 miles on them, and sold them with my 17x9.5" wheels for a very good price, because they still had more than 1/3 of the original tread left.
Peopls ASSumed the GC-C's wore prematurely, because the outer edge of the tread, where it wrapped around to the sidewall started with less tread depth, and they failed to rotate the tires as recommended, saw the "edge wear" and ASSumed they were wearing out. They weren't.
This is a GS-C with 45,000 miles on it (the narrow one on the right, obviously). Note what appears to be excessive wear on the outer edge of the directional tire - it was designed that way.
http://www.injuneer.com/images/photo...s/315v275a.jpg
Old Jan 23, 2010 | 05:14 PM
  #20
wa2010's Avatar
Thank you all for your replys
I have to say this car is faster than my 2001 z28 I really like this car, it may be older but it is strong. again thank you all for the info
Old Jan 23, 2010 | 05:53 PM
  #21
thewhite97z28's Avatar
I got my camaro book and I am pretty sure they used iron heads because they were afraid of blown head gaskets with aluminum heads on the iron block.
Old Jan 23, 2010 | 09:48 PM
  #22
On an f-body? uh-uh
Old Jan 24, 2010 | 09:54 AM
  #23
Do you have an ISBN reference for your "Camaro book"?
Old Jan 26, 2010 | 11:38 PM
  #24
briand069's Avatar
Here's a good link with sale flyers for the B4C Camaro's
http://www.performanceworks1.com/Police%20brochures.htm
Brian
fpete1992
Dec 11, 2014 03:51 PM
Bearmans
Dec 3, 2014 05:28 AM
USAirman93
Nov 24, 2014 03:37 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Paulberg
Jul 26, 2002 11:35 AM
