installing 96 white gauge overlays
Hey guys I need help installing theses things is it difficult? It looks like i got the hard plastic that replaces the whole dash comes with wires and a adjustable ****.. i heard you have to take the nedles off but afraid of screwing them up and not working right
Re: installing 96 white gauge overlays
they were a pain in the a** for me but it was also my 1st go at it on mine i had to thred the needles through the holes VERY VERY carfully and then i lined them up and had to super glue em on, they look good, should have pics later this week
Pull the needles off, peel off the factory face and apply the new face.
Now start the engine again, let it fully warm up, look at the pictures you took and stick the needles back on in the same places. Give each one a carefull gentle flick with your finger to seat it on its post fully. DO not use superglue.
For the speedometer-
Have a buddy pace you at 60 with your cruise control(or use a GPS) and stick the needle on at 60. Give it a gentle flick.
Or - if you have a scanner, you can use the scanner to obtain readings for speed and RPM from the PCM and set the needles to match.
When I'm going 60 MPH on my GPS, the PCM reads 60 and the speedo reads 61. Pretty close if you ask me. My tach is 200 RPM fast according to the scanner, I'll have to correct that next time I have the dash apart. I wish I had the scanner when I did my gauges, it would of made things alot easier.
99TransAmWS6
Feb 12, 2015 07:23 PM
slothgrant
Aug 22, 2002 03:01 PM
