how too
Re: how too
Originally Posted by flusz28
i want to remove the whole thing from the car..
Re: how too
I think there are a couple bolts that hold the base to a bracket by the spare tire. Take a look... its pretty obvious when you see it. I took everything off but the part that fills the hole in the fender, then put a vacuum cap on the threaded rod, so it looks like the antenna is "down". Not a lot of wieght to be saved with the antenna, but removing the wiring too makes it worthwhile.
Re: how too
i never use the radio - never did- i want a clean look with out spending the money to have it shaved and painted. i will have to fab something up to plug the hole in the black part where the threads.
Re: how too
I've always wanted to get an electric retractable antenna.......I suppose all it would take is to remove it like above and find a source for power.
Do our radio's (97+) have a power antenna out lead?
Re: how too
Re: how too
This won't help you, but I'm dropping my car off at the body shop later this morning to have the antenna shaved (as well as the raptor hood installed and body and paint). I've been wanting to do that since I bought the car!
