How many times can you resurface your brake rotors?
Old Dec 30, 2010 | 09:57 PM
Wilson's Avatar
Just curious as my 98 front brake rotors needs replacing. I turned them once when I first did the LS1 brake upgrade. Is there enough meat on the rotors to turn twice? If not, whats a good cheap replacement rotor? Thanks!
Wilson
Old Dec 30, 2010 | 10:46 PM
Re: How many times can you resurface your brake rotors?
The discs have a minimum allowable thickness number cast into them. You can't resurface if it will reduce the thickness to less than specified. According to my Chiltons, the 98+ minimum brake disc thickness is 1.209" for the fronts and 0.724" for the rear. But that's the same number they show for the 93-97 brakes, so I don't know how accurate it is. Chiltons isn't always the best reference. Maybe someone with a factory manual can confirm or correct.
Old Jan 2, 2011 | 06:22 PM
cohopefull's Avatar
The factory rotors were junk, don't even bother to turn them, buy a good after market product. They will be a little pricey but worth it in the long run.
Old Jan 3, 2011 | 10:13 AM
Marc 85Z28's Avatar
I recommend no more than once, under the best of conditions, assuming a minimal cut.
Nominal thickness is 1.260", with minimum machining at 1.223", and discard of 1.209".
Old Jan 7, 2011 | 01:33 AM
Fatdog2's Avatar
Your local brake guy will tell you what is acceptable,and what is not.I would just get them turned,and new brake pads,and flush the old brake fluid out.But if you can afford it,go with the bigger later model rotors.Myo2.
Old Jan 7, 2011 | 01:35 AM
Fatdog2's Avatar
whoops,I see you already did the upgrade.I'm going to bed now.
Old Jan 18, 2011 | 04:53 PM
Need4Camaro's Avatar
Wilson
Replace them... I tried turning my stock ones TWICE and they just warped again within a week... Not worth the hassle.
Jazsun
Dec 29, 2014 12:14 PM
Red97LT1
9
Dec 17, 2014 06:13 PM
bossco
Nov 29, 2014 10:18 AM
Jul 4, 2005 05:00 PM
