How to get my warning lamp through firewall, wheres the hole??
Old May 14, 2004 | 11:45 AM
lbrowne's Avatar
Question How to get my warning lamp through firewall, wheres the hole??
I have wired a warning lamp for my electric waterpump and right now I just have it in the engine bay, where the heck is the hole so i can route the wires through the firewall???
Thanks,
lbrowne
Old May 14, 2004 | 12:00 PM
carlos64030's Avatar
1st you should've drilled a hole in the firewall, then the wire should've been routed before it was connected to the water-pump. When you do run the wire through the firewall, make sure you use a rubber grommet to keep the wire from chaffing against the bare metal in the hole.
Old May 14, 2004 | 01:55 PM
lbrowne's Avatar
I plan on running the wires first, I wanted to make sure what I had done worked. I wouldn't be trying to push the lamp through the firewall.
I have to drill?!? Alot of cars have a hole to pass things through, I would have though this one did too.
Old May 14, 2004 | 02:01 PM
My Red 93Z-28's Avatar
there is a whole to the top left of the clutch pedal.
That is where I wired my Tach wire through.
Old May 14, 2004 | 02:40 PM
There's a huge rubber grommet in the firewall, right behind the PCM. I have a bundle of instrument wires and the -4AN hose for my nitrous pressure gauge run through there. You will need to pull the passenger side kick panel off to access the "inside" of the grommet.
Old May 14, 2004 | 06:41 PM
I stand corrected...looks like you won't have to do any drilling. I wasn't aware of any preexisting holes in the firewall that weren't already being used.
G-BODYT56
Jan 14, 2022 11:14 PM
drt
Sep 27, 2015 04:39 PM
marlar98
Sep 19, 2015 07:53 AM
RobFlag
Aug 29, 2015 11:40 PM
Boss002
Jul 24, 2015 10:47 AM
