Horn problems help
Old May 2, 2005 | 07:50 PM
crazypurgatory's Avatar
Question Horn problems help
I have a 1997 Z28.
Every time I wash it or it gets wet one of the horns won't work.
Has any body had this problem?
Once it dries both horns work.
What's up with that?
Thanks,
Chris.
Old May 2, 2005 | 10:12 PM
Kataklysm's Avatar
Re: Horn problems help
Is the water going into the horn? Try turning it down if it is...if the wires are getting wet and causing the problem melt plastic over them
Old May 2, 2005 | 10:27 PM
Water is not getting into the horns.
The horns are faceing down .
I am stumped.
Like I said I wash my car hood closed and after when I set the alarm.
One horn.
If I hit the horn button one horn.
Thanks,
Chris.
Old May 3, 2005 | 08:40 PM
Unhappy Re: Horn problems help
Ttt
Old Sep 30, 2005 | 04:48 PM
Angry Re: Horn problems help driving me crazy!
TTT
This problem is driving me crazy.
Does any body have some horn wiring diagrams?
thanks,
Chris G.
Old Sep 30, 2005 | 09:59 PM
Maybe a poor connection at the horn that is getting wet. Unplug it, clean it up and use some bulb grease on it.
Old Sep 30, 2005 | 10:13 PM
Question Re: Horn problems help driving me crazy!
I will try it cleaning the connections and put some bulb grease on them.
When I got the car the horn was bad I replaced them both and all was fine for a while.
But it kills only one horn even if I wash the car.
Witch means there is no water getting to the horns them selves.
That's why I'm thinking of something in the wiring harness might have gone wrong in it.
Chris G.
Old Oct 1, 2005 | 03:29 PM
GhostZ28's Avatar
ya my 99 Z is having horn problems... i've jacked with the wires and everything... only the high pitched tone is working. My father has the same problem with his 02 suburban. his low pitch horn wasnt working either, then just randomly one day we tried to use the horn and both sounded off loud and clear! i'm confused too..
liamcg97
Nov 25, 2019 05:55 PM
sahlomonic
Parts Wanted
Sep 19, 2015 10:17 AM
R@mpage
Apr 20, 2015 10:02 AM
AlaskaZ28
Apr 17, 2015 08:54 AM
fpete1992
Dec 11, 2014 03:51 PM
