High Flow cats
Re: High Flow cats
Might want to clarify....
-What year is your car? (Add a "signature" with year of car, trans type and major mods, so people don't have to ask
-"Stock headers" is confusing.... stock "manifold" or aftermarket "headers"? With stock manifolds, (93-95) the cat generally connects to the Y-pipe, and it is welded; (96/97) the drivers cat bolts to the manifold and the passenger cat is welded to the Y-pipe.
With headers, there may or may not be a Y-pipe involved, and the connection can be bolted or welded.
)-"Stock headers" is confusing.... stock "manifold" or aftermarket "headers"? With stock manifolds, (93-95) the cat generally connects to the Y-pipe, and it is welded; (96/97) the drivers cat bolts to the manifold and the passenger cat is welded to the Y-pipe.
Re: High Flow cats
Like Injuneer said, you might want to clarify some stuff, but this might help:
I had a 3" catback on my car, the rest of the exhaust was stock. I had two 3" hi-flow cats I wanted put on, and the only way the driver's side cat would fit was if it were moved lower and about a foot back from its stock location (just inside of the driver's side jack plate). This required a custom Y-pipe, but everything fits fine now, and I still have my stock exhaust manifolds. Maybe that will help...
Re: High Flow cats
http://216.178.81.107/iwwida.pvx?;it...0%201?comp=ppe
Plus, they are stainless steel and I got a pair for 140.00 plus free shipping.
Re: High Flow cats
really sorry i thought i had my sig set up didn't relise it was not.
its a 1997z28 camaro,
SLP loudmouth catback, stock manifold, has a stock trans, t56 M6.
my cats are pretty much shot right now.
1997 z28 camaro 13.8 at 104, intake/fuel regulator and Slp catback.
alex5366
Mar 8, 2015 11:32 AM
jeff94z28
Sep 11, 2002 02:01 PM
