help troubleshoot starting problem
Old Jun 12, 2007 | 10:48 PM
matt formula's Avatar
so sometimes when I go to start my car I turn the key and nothing happens, I try again and still nothing. I let the key rest at the on position for a few seconds then turn it again a little more slowly and it starts right up. Its not VATS cause theres no security light, I dont think its my starter cause i just replaced it last fall and it still turns strong. At this point it still starts the first time more than it doesnt but I have a feeling its just going to get worse. Anyone have any clue as to what I should look for?
Old Jun 12, 2007 | 11:36 PM
2000GTP's Avatar
It sounds like the symptoms of a bad ignition switch.
Old Jun 13, 2007 | 09:43 AM
OBE1 95Z28's Avatar
It also could be a loose wire to the starter. Check that all your connections are clean and tight.
Old Jun 13, 2007 | 09:59 AM
afr lt1's Avatar
I had a similar prob for a while that got progressively worse. In time in did not start more times than starting.
After going thru starters and checking wires and even hooking up a "hot start" wire to the batt, I had to take it to the dealer. They fixed some sort of "return ground" to the computer. I dont have a clue where it was, but maybe someone will chime in with the answer to that.
Oncomingstorm22
Jan 22, 2015 07:15 PM
HCz28
Jan 11, 2015 11:21 AM
97z28k&N
Jan 9, 2015 04:58 AM
97SSdude
Dec 31, 2014 07:43 PM
Brent94Z
Mar 21, 2002 04:44 PM
