help programming 2nd remote
Old 04-05-2018, 04:27 PM
95LT4Z28's Avatar
i have 1 remote that works fine and trying to program 2nd. went through shobox directions but cant seem to get it into the programming mode. i put a jumper between 4 and 8 but nothing happens. any suggestions ?
95LT4Z28 is offline
Old 04-08-2018, 12:51 AM
scottpdx2010's Avatar
Re: help programming 2nd remote
hi, you will need to re-program both of them the second one right after the first one
1) first remove the radio fuse.( the fuse box on the drivers side of the dash. fuse on bottom right. a 15amp fuse)
2) put key in ignition. turn key to on position then back to off position. do this three times within five seconds leaving the ignition in the on position. do not start the car during this process.
3)you will hear the locks locking then unlocking telling you have done this correct.
4) on the fob of the first one hold down the lock and un-lock buttons at the same time. (for about ten to twenty seconds.) you will hear a lock telling it was done correct.
5) after hearing that, pick up the second fob and repeat step four right away. (it should cycle through the lock again. showing all is complete.
6) put the radio fuse back in, and all should be good.
i am pretty sure this was the way i did it, but it was a while ago. now i only have one good fob. if this does not do it for you, you are above my skill level. i hope this helps you out.
scottpdx2010 is offline
Old 04-08-2018, 05:05 PM
95LT4Z28's Avatar
thanks for the reply - i tried that method but no luck. i think that method is for a 96 --i have a 95
95LT4Z28 is offline
Old 04-18-2018, 04:04 PM
95LT4Z28's Avatar
finally got it straightened out. somehow jumping 4 and 8 at the DLC didnt ground the circuit. i had to ground it at the keyless entry reciever. then i was able to get it in program mode and program my remotes as per shoebox's directions for a 95. many thanks to shoebox. without the drawings and schematics he has available i would have never figured it out. thanks
95LT4Z28 is offline
blackbirdta
12-09-2007 03:22 AM
jeffwof1z28
07-23-2007 10:53 AM
jimca
10-07-2006 08:41 AM
LT1WanaBe
07-31-2005 03:34 AM
parkerz28
04-20-2004 08:06 AM
Quick Reply: help programming 2nd remote
