2 questions- Need Help for programming remote!!!
Old Apr 20, 2004 | 07:25 AM
parkerz28's Avatar
My keyless/alarm is stock:
1) I bought the new remote from the dealer cause my old one got all worn out. I can't get the locks to cycle. I followed the directions from the manual- remove radio fuse, turn on/off three times. But then nothing happens Help!!
2) I saw a thread where Shoebox somehow extend with a wire the antenna to the keyless/alarm stock system, I was wondering if anyone had more specifics on where it is and how to go about. My range is pretty poor.
Old Apr 20, 2004 | 08:06 AM
Try cycling the key ON/OFF a little faster. You won't be able to do anything if you cannot get it into the programming mode.
After further use, it does not look like tapping onto the antenna for the remote had much real effect. My range is still a bit sproradic. It seems like I get interference sometimes. There are certain places I go and when I park the car, the remote just doesn't like to work. Other places it works fine.
Aaront810
Aug 29, 2020 09:34 PM
revrider
Cars Wanted
Apr 5, 2016 10:06 AM
MDZ28
11
Sep 24, 2015 09:15 AM
marlar98
Sep 19, 2015 07:53 AM
whitehooptie
Aug 10, 2015 07:02 AM
