Help Please- Misfires, Stumbling @ Idle, Log Included
Old Oct 9, 2006 | 09:15 PM
rhummer37's Avatar
Question Help Please- Misfires, Stumbling @ Idle, Log Included
Hey guys,
I have asked for help before from some of you guys before, but I still haven't fixed my problem.
At idle and low RPM, the car misfires in various cylinders, dropping the RPM's, oil pressure, and voltage. The car stumbles badly, shaking the entire car. This all began after I replaced the plugs and wires and the car sat, unplugged for about 3 months.
Since then, I have replaced the idle air control, coil, ignition control module, fuel pressure regulator, and just finished with a GMPP Optispark today. I have cleaned out the throttle body and run fuel system cleaners through the tank. Before and after the fuel pressure regulator, my fuel pressure was around 35 PSI. PCV and fuel filter were changed maybe a year ago and the car seemed to work fine. Plugs and wires were done six or seven months ago.
The problem remains, and here is a log from today.
http://www.yourfilehost.com/media.ph..._10_9_EDIT.csv
Please notice at the end of the log when I had it stopped and was playing with the trottle in neutral part of the time. The misfires seem to stop around 2000 RPM.
Also, the battery was unplugged over the weekend (while I was doing the opti) until right before I started the car and took this log.
If anyone could give any advice, I'd appreciate it.
rhummer37
Old Oct 10, 2006 | 07:17 AM
Re: Help Please- Misfires, Stumbling @ Idle, Log Included
Clearing the PCM before running a data log isn't really a good idea.. you loose the stored info for the long term fuel corrections.
You could also compact the file a lot by simply getting rid of duplicate units ("Hg/kPa, *C/*F, etc) for the same sensor, and the misfire records that aren't used in the LT1.
Old Oct 10, 2006 | 10:00 AM
rhummer37's Avatar
I know, the only reason it was cleared was because I unplugged the battery to work on the distributor.
I will take another log today and take out some of the unnecessary information like you said.
If there were any fields I was not logging but should, please let me know.
Old Oct 11, 2006 | 02:49 PM
rhummer37's Avatar
Here is a log I took from today. Car has had about 50 miles on it since the battery was reconnected.
http://www.yourfilehost.com/media.ph...10_11_EDIT.csv
I will probably take another log on Friday
kallcium
V6 Tech
Oct 7, 2015 03:39 PM
maybe2fast
Mar 16, 2015 11:59 AM
Alex Barnes
Jan 24, 2015 10:21 PM
Dyoung_Z28
Nov 25, 2014 05:26 PM
Dave19yz28
Jan 26, 2003 01:45 PM
