Help with my tail lights PLEASE!!!
Old May 28, 2005 | 09:59 PM
KillerTA's Avatar
The left side tail lights and stop lights are appear dimmer than my right side lights on my 97 TA.
I replaced the entire tail light harness and bulbs and the problem is still there.
When I compare the left and right side lights when they're out of the tail light lens, they appear to have the same brightness. When I put them in the lens, the left one appears to be dimmer than the right.
Do you think the problem could be the tail light lens? I don't see how that could be, but that is all I can think of at this point.
What about putting brighter lights in the left side lens? Does anyone know a part number for brighter bulbs?
Has anyone else had a similar problem?
Old May 28, 2005 | 10:39 PM
Re: Help with my tail lights PLEASE!!!
Same as the other thread.... why did you post the same problem twice in two different threads, on the wrong forum?
Moving to "General F-Body Tech".
Old May 28, 2005 | 11:49 PM
KillerTA's Avatar
It's not the same
Old May 29, 2005 | 12:52 AM
Z95m6's Avatar
Usually if a light is dim, you should look at the ground wire.
Old May 29, 2005 | 07:14 PM
KillerTA's Avatar
I only know of the one ground wire which is attached to the trunk latch, and its on there good.
Old May 29, 2005 | 07:24 PM
WS6NIGHTMARE's Avatar
OK so i just fixed this problem on my TA last week. Ill keep it short.. the sockets had to be replaced. Works like new ever since. There was quite a bit of corrosion and crap inside it. $15 fix.
Old May 30, 2005 | 01:46 AM
KillerTA's Avatar
Thanks but I don't think that's the case for mine. I replace the whole wiring harness with sockets and it's the same.
Someone said it could a discolored lens due to condensation. As far as I can tell, the bulb brightness is the same when they're out of the lens.
Old May 30, 2005 | 04:49 AM
Just check the sockets and see if they are crapped out, if so its a cheapy fix. I thought about that discolored lens thing too, but nope. I studied the wiring schematics and all that good stuff but in the end just took 15 minutes. And i drilled a few holes in the bottom of my lights to let any water that may get in again drain out.
Klypto
Parts Wanted
Apr 22, 2015 07:08 AM
Z28amustangklr
Middle Atlantic
Mar 28, 2015 03:08 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
JoFerZ
Aug 31, 2003 12:49 AM
