Help!!!...Headlight gremlins!!! >>>
last night I turned my lights on in my 95Z, and my low beams worked ok, but when I turned on the high beams, both right side lights and the running light went out...In addition...the dashboard indicator shows the right turn flasher with a steady(not blinking)light...In addition, as if I NEED more...My low coolant light comes on when I turn my low beams on, and goes out when I switch to high beams...AND....I noticed when my low beams are on there is a faint glow in my high beam lights, both sides!!!
I have checked my coolant level(OK), and tried a new bulb unit on the right high beam..($25 bucks!!!OUCH!!!)...I am suspecting that something is amiss in my headlight switch on the dashboard, but I cannot seem to get the procedure for removing it right...It looks like it should just need 1/4 turn to line up with the slot, but it won't budge....
Also, I would like to check the breaker for the headlights, but can't find it!!!...Any help would be appreciated....BTW, I did a search for "headlight problems" and got @ 5 pages about T/A light motors...;-(, and virtually no Camaro help....
user 647483
Aug 24, 2006 05:31 PM
Dave Hacker
Jun 13, 2006 06:47 PM
doc212121
May 7, 2004 07:15 PM
