Help me beat the electrical gremlins
Old Jun 12, 2006 | 06:40 PM
Dave Hacker's Avatar
My 93 Formula has been sitting for a couple months waiting for new opti. Got opti installed and now the gremlins are alive and well.
Wiper motor buzz's and moves very very slow. Thought the motor was bad so I replaced it and it still does it.
Drivers side front turn signal and parking light stay on when the car is running only. It wont come on until the motor is running and wont go out unless the key is turned off.
Fans wont come on at all.
Headlights wont pop up and when they are down I can hear the motors clicking. Had to unplug the motors to keep them from clicking.
Have checked all fuses.
Please help before I give it a REAL flame job.
Thanks, Dave
Old Jun 12, 2006 | 11:37 PM
Re: Help me beat the electrical gremlins
Are you sure no varmints have snacked on your wiring while it was sitting up?
Old Jun 13, 2006 | 12:00 AM
Sounds like your battery is extremely weak.
Old Jun 13, 2006 | 02:07 AM
Rashiki's Avatar
It does sound like the battery is kinda beat.. how does it start?
Maybe clean up the visible grounds, corrosion can wreak havoc on electrical components.
Old Jun 13, 2006 | 09:22 AM
The battery is a new fully charged Die Hard. The car starts and runs great. The pass side signals and lights work normal. I traced the engine bay harness to the firewall and all looks good and not chewed on. I have the bottom of the dash apart and all looks good there also. Is it possible the problem with the wipers and turn signal are messing up in the signal switch since the wipers are there too? If that is the case it still doesnt address the fans and headlight motors. Will clean all the ground points and see what happens.
Old Jun 13, 2006 | 06:47 PM
IROC-T's Avatar
For the wiper motor, try wetting the window and see if they speed up. Sometimes the blades will grab a dry window an slow them down. If they run normal with a wet window replace the blades.
football4life
Oct 4, 2015 07:48 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Daluchman1974
Sep 11, 2015 06:12 AM
blaze309
Sep 8, 2015 05:27 PM
plattted
West South Central
Sep 7, 2015 02:45 PM
