Help with Electric Windows
Old Mar 16, 2008 | 06:29 AM
Lvs2MffDv's Avatar
Hi,
Added the below to a prior post, but got no more response. So, posting as a new item.
First, thanks for all the info from those who have responded thus far. So far, not quite what I need, though.
I believe the window control unit is a stock '97. It is abou 4" x 2.5" x1" w/ 529T on the cover and wire assignments on the reverse side. There are a total of ten wires , labeled as follows:
Blue motor, side 1
Gray (-) Output through activation, side 1
Brown Switch, side 1
Orange (-) Activation input, side 1
Black (-) Chasis ground
Gray/Black (-) Output through activation, side 2
Red (+) 12V constant
Orange/Black (-) Activation input, side 2
Green motor, side 2
White Switch, side 2
The Orange & Orange/Black are twisted together and are slipped over a terninal on a relay, BEULER 12V 30/40A #BU-5083-0000
Terminal layout is 1, then 3 across, then 1. I'll call them 1-5.
__1
2 3 4
__5
The #1 terminal leads out to ?. orange & orange/black are on #4, and have a resistor, or diode between the wires and terminal connecton.
#2 #3 are jumpered together, with #3 having a second wire attached leading out to ?
I have access to the GM 2 volume repair set for the 1996 Camaro & Firebird, but have been unable to find anything (so far) specificly for the '97.
Should have said all this in the 1st posting. Sorry, my bad! I was worried of it being too lengthy.
Maybe these details will better enable someone to help me out here.
I am not a real keen electrical guy, but I do follow directions very well. I am able to follow basic circuits. I make very good soldered splices, and other connections, and wrap the soldered sites well or use shrink sleeving to avoid any shorts etc. I understand how relays function, basicly, like in a starter circuit, and have installed several multi-amp audio systems with active/passive cross overs and multi-speaker arrays, without too much trouble, and that, my friends, is the limit of my "electrical expertise".
Thanks again to all you helpful persons, both for your time and interest in helping other enthusiast. Great web site, this!
Regards to all, Lvs2
Last edited by Lvs2MffDv; Mar 16, 2008 at 06:33 AM. Reason: realign terminal layout
Old Mar 16, 2008 | 07:47 AM
euforia51's Avatar
Maybe I shouldn't butt in, but I didn't read your first post, so this one is a little foggy to me... what are you trying to do?
Old Mar 16, 2008 | 08:25 AM
Lvs2MffDv's Avatar
The begining
My original inquiry .....
Looking to download an electric window wiring diagram, wire by wire, every connection, for a 1997 Camaro Z28.
I am trying to reinstall the power window control module, which was removed from the car, and all junction connectors and splice locations were removed. All I have is the module, connector, and about 10 wires, color coded, coming out of the modules connector. Each color code is labeled as to function of the modules cover.
So, because all the wire ends, etc, are removed, wiring harness plug to plug diagrams are no help. I need individual circuits, point to point, to recover the original connections.
There has to be somewhere on the internet that has detailed data available.
Any help is appreciated.
Thank you all in advance ...............
Old Mar 16, 2008 | 09:16 AM
Generally, the best thing is to "ttt" your original post, rather than reposting and losing the history.
https://www.camaroz28.com/forums/sho...d.php?t=588162
Old Mar 16, 2008 | 09:42 AM
euforia51's Avatar
Here is the best place to go for diagrams/how-to's and other great info if you don't have a manual.
Another plug for Shoebox!
Old Mar 17, 2008 | 12:36 AM
Lvs2MffDv's Avatar
I'VE BEEN TO ShOEBOX, AND IT SEEMS TO BE AN EXCELLENT RESOURCE FOR INFORMATION.
HOWEVER, IT HAS A DIAGRAM FOR A 1995. I HAVE THE FACTORY MANUALS(2 VOL.SET) FOR A 1996. (SAME AS THE '95)
I THINK 1997 CHANGED A FEW THINGS, (HOPEFULLY, WHAT I AM LOOKING AT), AND i HAVE BEEN UNABLE TO FIND ANYTHING YEAR SPECIFIC FOR MY '97 Z28.
AH, WELL, GUESS I'LL HAVE TO KEEP LOOKING.
THANKS TO ALL, REGARDLESS.
Lvs2
IndyZman
Oct 22, 2015 02:17 PM
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
z28cam1993
Sep 9, 2015 04:08 AM
plattted
West South Central
Sep 7, 2015 02:45 PM
