heater core or ?
Old Nov 6, 2008 | 10:17 PM
apyah's Avatar
heater core or ?
on my way home today noticed smoke behind car, 94 z28 no mods. pulled over and had fluid all over but couldnt determine what it was, but there was alot, wasnt low on oil or trans fluid. only thing that was very low was coolant, coolant was brownish should have been flushed, anyway it is all over and really leaked bad at higher speed which is odd. nothing on floor inside yet this week I noticed my windows fogging a bit I had to wipe the windshield off this week thought it was strange. only question now is what would make it blow all over the undercarriage. have not got under there yet. any help on this would be great. Allen
Old Nov 6, 2008 | 10:30 PM
bombebomb's Avatar
Does it smell like anti-freeze? Believe me if you busted a coolant line, or a heater core, you could smell it really strong.
Where do you consider "all over" all over the top of the engine, or what, does it appear to be in any concentrated area more so then other places?
EDIT: protect that opti! lol
Old Nov 7, 2008 | 04:36 AM
apyah's Avatar
none on the engine all from the back of the engine and back almost covering the center section about 2 feet wide to the back off the car almost seems the most by the trans pan and flywheel inspection cover
Old Nov 7, 2008 | 05:17 AM
You should be able to tell what kind of "fluid" it is. Sounds like you aren't even sure. Makes it almost impossible for anyone to tell you where its coming from. Oil and trans fluid are a lot different than coolant in feel and smell, and often in color. Does a puddle form under the car when its sitting? Are there visible drips, or just a wet stain? What color was the smoke you saw behind the car? By "down the middle" do you mean the middle of the undercarriage - i.e. near the drivesahft tunnel?
Where did you check the coolant level? In the reservoir, or in the radiator? Did your low coolant light come on? Did you check the heater hoses where they attach to the heater core pipes, on the firewall?
Old Nov 7, 2008 | 03:38 PM
apyah's Avatar
at first I could not tell, it is antifreeze sorry I did not make that clearer, the majority of it was around the trans pan and flywheel inspection cover and back. exhaust trans mount ect. Iwill get under there tonight and see and also pressure test the system. Allen
Old Nov 7, 2008 | 03:56 PM
seawolf06's Avatar
Sounds like the steam pipe area.
You don't notice it overheating?
Old Nov 7, 2008 | 04:05 PM
apyah's Avatar
not at the time no overheating although temp rose just a bit, where is steam pipe area?
Old Nov 7, 2008 | 07:45 PM
apyah's Avatar
sorry I was wrong in my discription know the problem now
well I was very wrong after further inspection it is some sort of trans seal in the front of the trans, I was wrong about the fluid am certain now though, my apologies for the wrong info, the coloring had me guessing wrong, now off to a different section fro trans questions, once again thank you and sorry for the misinformation. this is a great site
Old Nov 7, 2008 | 08:08 PM
bombebomb's Avatar
Seriously, you can smell anti-freeze heavily. I was quite surprised when you said it was anti-freeze.
ducttape1975
Classic Engine Tech
Mar 26, 2016 04:17 PM
Quickss96
Jan 29, 2016 05:56 PM
Fatdog2
Sep 16, 2015 11:04 PM
Pwilson59
Sep 3, 2015 08:47 PM
ducttape1975
Jul 10, 2015 06:29 PM
