'92 B4C not passing emissions
Old Nov 7, 2008 | 02:37 AM
aznguy888's Avatar
I have a 92 B4c with a 350 TPI. It's been sitting for a couple years. I recently changed fuel pump(twice), fuel pump relay, MAP sensor, TPS( but I didn't adjust TPS), plugs, wires, cap, rotor, ECM, Eprom, and it failed emissions on HC, CO, and NOx. I live in Colorado and someone told me to advance the timing 1 degree for every 1000 feet above sea level, so I have it at 10.5 degrees. I think the catalytic converters are bad, but I don't know. It is running rich, I can smell the gas. Does anyone have any ideas? I have a Chiltons manual but I'm just a do-it-yourselfer, with no mechanics degree. Please help.
Old Nov 7, 2008 | 01:56 PM
n2ceptor's Avatar
Throwing any codes???? How about the O2 sensors????? If it is the original cat, then it miht need changing..
Old Nov 7, 2008 | 10:02 PM
aznguy888's Avatar
I replaced the O2, cats are fairly new. Chopped them and they looked ok. No codes, but it is running rich, you can smell the gas. Maybe purge canister is original. Also i'm not susre what to set the timing. Anyone have any ideas at altitude? She runs great, but won't pass.
David Dempsey
Mar 12, 2016 12:42 AM
IndyZman
Oct 22, 2015 02:17 PM
sleeperZ96BT
Sep 9, 2015 08:28 AM
Steve69SS396
Track Kill Stories
Aug 17, 2015 08:48 PM
Cam's maro
Aug 11, 2015 07:45 AM
