Gutted Dash: Neither Windows work!! Need Help!!!?????
We removed the Hvac and Heat/AC reassembled everything and we went to roll the windows up and neither of them have power. When the key is foward and you hit the window up button the Seatbelt light blinks and the door alarm beeps very fast. What did we miss some relay, everything was plugged in that is getting used besides airbag module, heat ac controls. Any help.?????
Re: Gutted Dash: Neither Windows work!! Need Help!!!?????
What did you do with the RAP (retained accessory power) module? That supplies the windows and radio to allow them to operate for 10 minutes when the key is turned off. Its located:
http://shbox.com/1/express_down1.jpg
On a 1999, all the RAP fuctions are in the BCM. Did you hook the BCM back up? It's usually attached on the HVAC housing under the RH side of the dash.
