fuses or wiring?
Old Oct 12, 2005 | 12:57 PM
BlackIsSecksee's Avatar
fuses or wiring?
ok i noticed my turn signals on the left side are out but not on the right
my dad and i checked the fuses and put new fuses where the turn signals and tail lights go and no change occured
does anyone have any idea off the top of their head what it might be?
not sure if it would be wiring because wouldnt all the turn signals not be working?
or is it something i will have to take to a shop to fix
any input would be appreciated since i dont know squat about cars
thanks in advance
Stephanie
Old Oct 12, 2005 | 01:21 PM
Bert02SS
Guest
Posts: n/a
Re: fuses or wiring?
Steph--
You probably have one bulb burned out, or a filament of one bulb. Check them all out.
Old Oct 12, 2005 | 01:25 PM
Originally Posted by Bert02SS
Steph--
would one bulb cause both the front and back turn signals to not work?
Old Oct 12, 2005 | 03:52 PM
lt11997's Avatar
Usually if one of them burns out and you use your turn signal the light on the dash will come on but it won't flash.
Old Oct 13, 2005 | 10:23 AM
mr_camaro96z28's Avatar
If one of the bulbs is burned out the light will come on and not flash if one side is not working at all and the other is I would get a flasher it's a round solenoid under the dash. To find it turn on the right turn signal and you will be able to feel it clicking.
Old Oct 13, 2005 | 11:47 AM
87DJP2001's Avatar
Replace the Flasher as stated in the previous post. Do the simple things first ( fuses, bulbs, flasher) before looking at major items (wiring).
Old Oct 13, 2005 | 01:11 PM
never knew that ..thats probably what it is because my whole right side is working and my whole left side isnt (as far as turn signals go)...my dad will be home soon so we will check it out then
thanks guys
eanhl2004
Apr 4, 2015 12:01 PM
jayvar
Feb 2, 2015 10:00 PM
Head Hunter
Aug 29, 2002 07:21 AM
$hawn
Aug 17, 2002 04:37 PM
