Which fuel pump is easy and cheap?
Old Mar 27, 2006 | 02:25 PM
95patriotZ's Avatar
I need to get a new fuel pump and want something that will be basically plug and play. I am pretty mechanically inclined so I should have no problem with it. I just want something reliable and easy to install. I don't need anything for high horsepower because I am basically stock. Thanks guys.
Old Mar 27, 2006 | 02:35 PM
onetransam4u2nv's Avatar
Re: Which fuel pump is easy and cheap?
im lookin for one too i have a 95 trans am 6 psi powerdyne and lt4 hotcam kit getting ready to install and i don't want to run a inline and the fmu no trap door just a simple direct plug in in tank 255lph. thanks for any help
Old Mar 27, 2006 | 03:04 PM
Dansean1's Avatar
You should google Walbro's website and get their intank 255lph. Its probably about $115 shipped or something and supports good hp. Walbro is a good brand and I believe that they are used in many Fords Lightnings, Cobras, etc.
You guys dropping the tank or cutting thru the metal?
I cut thru the metal on mine, now swaps take 20 min and the carpet covers it.
Old Mar 27, 2006 | 03:10 PM
WS Sick's Avatar
I like the Racetronics pump. Iits a255 LPH that drops in the stock bucket.
Racetronics
Old Mar 27, 2006 | 04:54 PM
2000GTP's Avatar
Another vote here for the Walbro pump, a 125 bucks or a little less can snag you one.
Old Mar 28, 2006 | 05:35 PM
Spinner's Avatar
Racetronics kit is as plug and play as it gets. A+ kit
Old Mar 28, 2006 | 09:19 PM
OBE1 95Z28's Avatar
I installed a Walbro 255 and had to carve up the fuel bucket to make it fit. If I was to do it again, I would go the Racetronix's route. It's worth a few more dollars to keep the fuel bucket intact and upgrade the wiring.
Old Mar 28, 2006 | 09:39 PM
2QUIK6's Avatar
The Racetronic kit uses a Walbro 255. You do have to do a small mod to the bucket. Basically by carefully prying off the bucket top, then cutting 2 ribs out of it, which is easily done with a pair if wire cutters or a dremmel. There are instructions on this with the racetronic kit.
Old Mar 29, 2006 | 10:11 AM
nfa's Avatar
nfa
i just bought the racetronix kit and hot wire kit. all plug and play....
Old Mar 29, 2006 | 07:43 PM
OBE1 95Z28's Avatar
The Racetronix Walbro pump is modified to fit the bottom strainer basket on the stock bucket. A stock Walbro doesn't fit the strainer. The bucket modifications with the Racetronix setup is some slight shaving of some support ribs inside the bucket.
Old Apr 13, 2006 | 04:26 AM
30thTA0525's Avatar
you got pics on where you cut & what you did? im pretty interested in that.. i had too drop the tank on mine not too long ago and hope too never do it again atleast without the rear end under it at all ThirtyTA0525@aol.com
Old Apr 14, 2006 | 12:06 AM
kingslam's Avatar
the easy part does not come until you get the rear end out!!!!
Old Apr 14, 2006 | 12:12 AM
Skull Leader's Avatar
Lightbulb Re: Which fuel pump is easy and cheap?
Even easier if you chop the top over the tank like I did. Well worth it my second pump install.
grabbem88
Apr 16, 2015 06:57 PM
Scottyboy
Feb 11, 2015 10:28 PM
RiverMutant96
Jan 30, 2015 09:21 AM
ANDYZ28
Dec 29, 2014 09:13 PM
