Which fuel pump is easy and cheap?
I need to get a new fuel pump and want something that will be basically plug and play. I am pretty mechanically inclined so I should have no problem with it. I just want something reliable and easy to install. I don't need anything for high horsepower because I am basically stock. Thanks guys.
Re: Which fuel pump is easy and cheap?
im lookin for one too i have a 95 trans am 6 psi powerdyne and lt4 hotcam kit getting ready to install and i don't want to run a inline and the fmu no trap door just a simple direct plug in in tank 255lph. thanks for any help
You should google Walbro's website and get their intank 255lph. Its probably about $115 shipped or something and supports good hp. Walbro is a good brand and I believe that they are used in many Fords Lightnings, Cobras, etc.
You guys dropping the tank or cutting thru the metal?
I cut thru the metal on mine, now swaps take 20 min and the carpet covers it.
I installed a Walbro 255 and had to carve up the fuel bucket to make it fit. If I was to do it again, I would go the Racetronix's route. It's worth a few more dollars to keep the fuel bucket intact and upgrade the wiring.
The Racetronix Walbro pump is modified to fit the bottom strainer basket on the stock bucket. A stock Walbro doesn't fit the strainer. The bucket modifications with the Racetronix setup is some slight shaving of some support ribs inside the bucket.
Originally Posted by kingslam
the easy part does not come until you get the rear end out!!!!
