Fuel leak
Old Oct 1, 2018 | 02:05 AM
Devinmichael87's Avatar
Fuel leak
I have a fuel leak, my bleeder valve is seeping fuel out of it once I turn the key to on position but I don’t turn on the car. The bleeder valve looks just like a valve core stem but I was wonder how I can fix the leak without having to buy a new fuel rail?
Old Oct 1, 2018 | 09:01 AM
Re: Fuel leak
Is it leaking from the core? The valve core can be replaced, just like the core in a tire valve. Here’s an example of a GM replacement core and cap. You would have to check the part number for your specific year/model.
https://www.summitracing.com/parts/a...iABEgKL5_D_BwE
Old Oct 1, 2018 | 10:46 AM
DrewHMS97SS's Avatar
Re: Fuel leak
If the leak is due to port being damaged (in the case you have lines attached to the port), you can get a lapping tool to fix it: https://www.summitracing.com/parts/kts-ff-4/overview/
Another thing to look for is an over tightened port. I was an idiot on mine and broke mine. If this is the case, you will need to find a shop (or if you can do it) that can weld very thin material. I think I paid $20 for the fix to mine.
Drew24
Jun 2, 2010 12:50 PM
JennyOnNos
Feb 4, 2010 08:09 PM
yy
Apr 21, 2008 09:26 PM
dirtybird96
Mar 24, 2007 10:55 AM
elementaltoad
3rd Gen / L98 Engine Tech
Aug 7, 2005 10:59 AM
