Fix for sagging door? Can I add power windows to my car?
Old Mar 3, 2006 | 11:57 PM
91 Camaro RS's Avatar
My driver side door is sagging, it isn't very bad (about half an inch) but the passenger side door doesn't sag at all (it has a problem too though, it rattles when I close it). I'm getting my car painted soon and I don't want the door rubbing the paint off because it's sagging if the problem is easily fixable. Is there any fix for this?
Second question, is it possible to add power windows to my car if I get all the components off of a donor car (like from a salvage yard)? Are the power windows a stand alone system or is it integrated with a computer or some other stuff or some crap like that?
Old Mar 4, 2006 | 04:16 AM
MasterEvilAce's Avatar
Re: Fix for sagging door? Can I add power windows to my car?
Door sagging: You need to replace the door hinges, as they are the weak link.. I don't know much more than that, it's been talked about a lot though on TGO (thirdgen.org)
Power windows: Sure, it's possible. You'd need the window switches, relays, wiring, possibly some window mounting hardware (not sure), and door panels, unless you're going to cover the hole from the crank yourself
cmdeshon
Dec 12, 2014 10:51 PM
CaRParts102
Dec 6, 2014 08:45 AM
siguy
Nov 27, 2014 10:07 AM
USAirman93
Nov 24, 2014 03:37 PM
MilkyClr69
Jul 29, 2002 10:01 AM
