First steps of pulling engine(LT1)?
Old May 16, 2005 | 08:01 AM
  #16
EKO's Avatar
EKO
Re: First steps of pulling engine(LT1)?
Originally Posted by vonmoldy
Can the entire suspension come down on the kmember with the engine? My idea is to leave the engine on the k member and do the head cam swap headers at the same time and then put it back up there.
Yes. Thats how I got my pull out, still on the mounts, just disconnected the k member and lifted the car off the engine/trans and put it on a pallet.
Old May 16, 2005 | 08:51 AM
  #17
Z95m6's Avatar
http://ken.lowrance.com/Projects/Hea...ineRemoval.htm
Old May 16, 2005 | 02:52 PM
  #18
easyc4's Avatar
Here is the easiest way possible. First ajck it up and put a cart or dolly under neath it, something that is low enough to the ground to give you clearance, but high enough to touch the k member. then just look for everything that is connected to teh body around the engine and disconnects it. things like throttle cables, brake lines (from the solenoid), fuel lines,driveshaft, shift linkage, sterring linkage, etc.. unbolt the k member from the car, use a cherry picker to lift up the front of the car, and slide out the entire engine and tranny setup out along with teh suspension. i pulled everything out from one car and had it bolted back into another car in less than 2 hours.
Old May 17, 2005 | 08:03 AM
  #19
JeffK's Avatar
I just had my motor pulled by a local speed shop. They told me the only way they pull any motor on an Fbody is from the bottom since it is much easier. I figure they would know since they do it all the time.
Gtpguy
Jan 26, 2015 04:50 PM
cmdeshon
Dec 12, 2014 10:51 PM
formula218
Dec 2, 2014 04:27 PM
Lt1son
N2O Tech
Nov 25, 2014 01:52 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
