First steps of pulling engine(LT1)?
Re: First steps of pulling engine(LT1)?
Originally Posted by vonmoldy
Can the entire suspension come down on the kmember with the engine? My idea is to leave the engine on the k member and do the head cam swap headers at the same time and then put it back up there.
Here is the easiest way possible. First ajck it up and put a cart or dolly under neath it, something that is low enough to the ground to give you clearance, but high enough to touch the k member. then just look for everything that is connected to teh body around the engine and disconnects it. things like throttle cables, brake lines (from the solenoid), fuel lines,driveshaft, shift linkage, sterring linkage, etc.. unbolt the k member from the car, use a cherry picker to lift up the front of the car, and slide out the entire engine and tranny setup out along with teh suspension. i pulled everything out from one car and had it bolted back into another car in less than 2 hours.
I just had my motor pulled by a local speed shop. They told me the only way they pull any motor on an Fbody is from the bottom since it is much easier. I figure they would know since they do it all the time.
Gtpguy
Jan 26, 2015 04:50 PM
formula218
Dec 2, 2014 04:27 PM
Darth Xed
13
Jul 22, 2002 12:45 PM
