Eliminate/Modify Condenser Shroud
Old Jun 23, 2012 | 01:01 AM
ascastil's Avatar
Found a place i would like to mount my tranny oil cooler. The plastic piece that goes in the FRONT of the a/c condenser is slightly in the way. Is it ok to delete or cut a piece out to make the cooler fit. I know that air to cool the motor is routed up through the bottom, Im not sure if the plastic piece on the front of the condenser plays a role. It looks like it only holds it in place from the top, the thicker piece in the middle of the shroud maybe directs air flow into the radiator. It seems to easy to delete this piece, it has to have a purpose....
Old Jun 23, 2012 | 10:56 AM
ascastil's Avatar
Re: Eliminate/Modify Condenser Shroud
Anyone?
Old Jun 24, 2012 | 10:04 AM
mab6680's Avatar
are you talking about the shroud on top with the decals on it pic maybe
Old Jun 24, 2012 | 12:14 PM
I'd go look at my car for you, but the condensor has been deleted and I have an aftermarket radiator. What you don't want to cut into is the big curved panel that sweeps up from the bottom opening, right in front of the air dam. That guides the pressurized air into the condensor and radiator.
The shop manual isn't very clear on the structure either.
Old Jun 25, 2012 | 09:08 AM
bobdec's Avatar
Here is a pic of my '94 w/B&M SuperCooler model #70264 (6 X 11 X 1.5 inches) installed w/my Yank SS3200. It squeezed it up in front of the condenser w/o any cutting or modification required. As Fred stated that plastic shroud on top of the cooler (can't see in pic) guides air from the air dam to the condenser/radiator. I was concerned about the B&M blocking some air to the cooling system, but never saw a blip on the temp gauge between before and after .
[IMG][/IMG]
Devinfoote87
Feb 12, 2016 03:21 PM
Tires_Smokin
May 19, 2003 02:05 PM
highlanderOLD
V6 Tech
15
Mar 16, 2003 12:47 PM
brodyscamaro
3rd Gen / L98 Engine Tech
Mar 11, 2003 07:58 PM
