Electrical Problem
Old Mar 22, 2007 | 05:28 PM
NORALTA's Avatar
Electrical Problem
98 TA A4 150k miles stock
Problem is with the power to the radio and power windows/locks. I can be going down the road and my radio will shut off and the windows/locks at both doors won't work. I'm not loosing total power to the radio because i don't loose my presets. it might stay off for a few seconds and go back off and on or it my stay off for an hour. It's really starting to **** me off because i can't figure it out. I've checked connections at the radio and the window motors. It's obviously somewhere else but after looking at a schematic i'm even more lost.
Anyone got any suggestions or better yet know the fix?
Old Mar 22, 2007 | 08:03 PM
DR.ZED's Avatar
The power door locks don't work at all? What about the keyless entry?
I'm having a sort of problem... but I haven't driven the car yet for any extended distance. Will do this weekend.
Old Mar 23, 2007 | 10:33 AM
NORALTA's Avatar
keyless entry?? never tried
Old Mar 23, 2007 | 04:54 PM
Both the sound system and the power windows are fed through the RAP (Retanied Accessory Power) module. If you have an intermittent power problem, check the RAP module. Not sure if they ever integrated the RAP module with the BCM (body control module), or what year they might have done it.
Old Mar 23, 2007 | 06:08 PM
DR.ZED's Avatar
Check the reply in my thread.
Old May 18, 2007 | 10:07 AM
Schweet97Z's Avatar
ok im bringing the thread back to life, because im having the same exact problems, except my doorlocks still work. where exactly is RAP, and BCM? How do i test to see if they are bad? also i nolonger have low beams, just highs and fog lights. could this module be acting funky that it wont give me any low beams?
Old May 18, 2007 | 05:18 PM
likittysplit's Avatar
Check this out:
http://web.camaross.com/forums/showthread.php?t=521034
Old May 18, 2007 | 06:13 PM
DR.ZED's Avatar
For the lights issue, I'd check the two ground on the rad support under the hood. Look near the high beams on the frame support and you'll see a set of wires bolted to the body on either side. Check for contact. Clean and reseat.
Old May 20, 2007 | 10:16 AM
Schweet97Z's Avatar
thanks for the replys. but one more thing, where is the bcm actually located? isnt it under the black cowling right under the glove box?
Old May 20, 2007 | 10:40 AM
2000GTP's Avatar
Its located under the right hand side of the dash.
Old May 20, 2007 | 11:03 AM
Schweet97Z's Avatar
any pics? or will i notice it when i see it?
Old May 20, 2007 | 01:34 PM
2000GTP's Avatar
Brent Franker has a few pics on his site: http://www.bfranker.badz28.com/fbody/alarm96up2.htm
liamcg97
Nov 25, 2019 05:55 PM
eanhl2004
Apr 4, 2015 12:01 PM
robcarnut
Mar 20, 2015 03:40 PM
BMX Dad
Jan 23, 2015 07:00 PM
97z28k&N
Jan 9, 2015 04:58 AM
