ECM Diagram
Old Nov 2, 2014 | 03:27 PM
Black93lt1's Avatar
ECM Diagram
I need help finding out which wire on the PCM 16159278 is the signal wire for the TPS
Old Nov 2, 2014 | 04:44 PM
Re: ECM Diagram
http://shbox.com/1/1993_ecm_1.jpg
Old Nov 2, 2014 | 04:47 PM
Black93lt1's Avatar
Re: ECM Diagram
Do u know which color input C is on
Old Nov 2, 2014 | 05:50 PM
GaryDoug's Avatar
Prominent Member
Re: ECM Diagram
green pcm connector
Old Nov 2, 2014 | 06:55 PM
Black93lt1's Avatar
Re: ECM Diagram
Thank u I was able to run a fresh signal wire to check and see if it was grounding out some where on the inside but there was no change of volts with the change in throttle position
G-BODYT56
Jan 14, 2022 11:14 PM
93 RedBird
Nov 15, 2015 08:24 AM
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
