ECM Diagram
I need help finding out which wire on the PCM 16159278 is the signal wire for the TPS
Re: ECM Diagram
Re: ECM Diagram
Do u know which color input C is on
Re: ECM Diagram
green pcm connector
Re: ECM Diagram
Thank u I was able to run a fresh signal wire to check and see if it was grounding out some where on the inside but there was no change of volts with the change in throttle position
