Dyno Tune Cost....
Old Apr 9, 2004 | 11:48 AM
Fast S/C '94Z's Avatar
Dyno Tune Cost....
Just wondering what some of you have paid in the past to have your car dyno tuned. Also if you know any places good in FL, that would great also. Thanks for any replies.
Ray
Old Apr 9, 2004 | 11:49 AM
Red96Lt1's Avatar
I called someone and they said like $1000. I'm sure you could get one cheaper.
Old Apr 9, 2004 | 11:53 AM
Prorac1's Avatar
i have always heard 450-500 dollars. Hope this helps, Prorac1
Old Apr 9, 2004 | 11:55 AM
importeater's Avatar
$1000!!
Look in the regional section, alot of times they will have a "group" dyno tune day. There is on in the Northeastern section now if there is 7+ cars is $250.
Old Apr 9, 2004 | 12:10 PM
WOT's Avatar
WOT
Here TEA does a full dyno tune for around $400. If your car is mostly stock they told me they could do it for $150-200.
Old Apr 9, 2004 | 12:20 PM
rskrause's Avatar
Moderator
The shop I'm associated with charges $125/h.
Rich Krause
Old Apr 9, 2004 | 12:26 PM
Teek's Avatar
The first time it was tuned Ed Wright did it. It cost a flat rate of $550 and he spent all day on tuning. Had mechanical problems, and the tune didn't come out quite "right".
The second time around we decided to tune it ourselves- and was given a rate of $120 an hour to use a dyno. We spent several hours on it and the guy gave us a HUGE discount.
Still needs more tuning/dyno time though.
Old Apr 9, 2004 | 08:44 PM
Fastbird93's Avatar
Originally posted by importeater
$1000!!
That 7+ for $250 is only for 86-93 guys because we use chips.
94+ LT1's are going to be $200 plus dyno time, which is down to <$100 a person now.
I'm the POC for that above mentioned dyno tune day.
Old Apr 10, 2004 | 10:32 AM
95firechicken's Avatar
Re: Dyno Tune Cost....
Ray
jeremy at www.fasterproms.com is in tampa, and does all the gm cars around here. reayy great guy and know his stuff.
Old Aug 9, 2024 | 08:41 AM
SteveC's Avatar
From: Poway CA, where GOD and the sun always shines
Thumbs up Re: Dyno Tune Cost....
My dyno tune was $647 dollars, the tuner went through the entire PCM, and my vehicle was on the dyno for 6 hours. I needed extensive work due to a higher stall, and lower rearend gears. My shift points (A4) was one of the issues, also my WOT was lean (15.2) from the factory, it was changed to 13.5. All my smog parameters stayed the same.
BUBBA
Apr 2, 2008 04:44 AM
dueno
Mountain
Mar 21, 2008 01:36 AM
wdtiger
Apr 24, 2006 07:25 PM
k9ulan
Jun 14, 2003 12:51 AM
alexis01
West North Central
Feb 14, 2003 10:21 AM
