Drivers Side Window
Old Jul 15, 2004 | 01:46 AM
  #16
Nittanymarine's Avatar
Its the motor. I hated replacing those things...best of luck to you man
Old Jul 15, 2004 | 04:31 AM
  #17
Blue96z28's Avatar
Well obviously theres alot of things that could go wrong, its even possible that it could be a fuse/relay problem or something, or even the switch, but most likely its the motor and thats the best place to start, those things suck anways, have a life of like 30,000mi normal use.
Old Jul 15, 2004 | 09:24 PM
  #18
RealZ28's Avatar
I just finished replacing my window motor today. $56 at AutoZone. Wasn't too bad a job. Also stuck a little "JB Weld" on that wobbly roller post. Works great now
Old Jul 16, 2004 | 12:32 PM
  #19
ChrisUlrich's Avatar
Why is everyone so sure its the motor? What does the regulator do?
Old Jul 16, 2004 | 02:52 PM
  #20
RealZ28's Avatar
Well...diagnosing a car is just like a doctor diagnosing a patient. You look at the symptoms and make a decision based on experience. When it comes to power window issues it's almost always the motor that is the problem. Look at all the people from this message board who have had power window issues and it's almost always the motor. It COULD be another problem with the window but chances are it's not.
The window regulator is the mechanical link between the window motor and the window itself. There are tracks and rollers which control height. It's a unit that looks like a pair of scissors. The window is counterbalanced with a spring to help keep the weight of the window neutral. In some cases the rollers become beat or the unit will rust and stiffen up.
Keenan
Jan 19, 2023 12:24 PM
mattstrike
Mar 11, 2015 07:33 PM
siguy
Nov 27, 2014 10:07 AM
squarehead
Nov 21, 2014 08:02 PM
The Seer
Nov 20, 2014 06:32 AM
