Drain fuel tank
Old Aug 5, 2009 | 10:29 AM
Z28WannaB's Avatar
Drain fuel tank
I was not able to find any threads that discussed on how to go about this.
How would I drain the tank?
Thanks in advance for any advice.
Old Aug 5, 2009 | 03:21 PM
Sick97SS's Avatar
http://www.nloc.net/vbforum/how-arti...nk-w-pics.html
even thought it's for a Ford Lightning, it "could" work for our cars.
i might be wrong. but i like the idea.
Old Aug 5, 2009 | 03:37 PM
rclearyiii's Avatar
Fuel Pump Method
Ijust bought a cheap external electric pump..like from a 85 cutlass and put rubber hoses on both ends of it. Simply connect it to your battery and drain out your tank via the longer rubber hose. Just a method I use.
Old Aug 6, 2009 | 11:18 AM
RUDEDOG's Avatar
1. Pull the 3/8 pressure line off fuel rail. 2. Clamp hose to it and route to a container. 3. Put 12 volts on Fuel pump test connector.
Old Aug 12, 2009 | 05:54 PM
Z28WannaB's Avatar
Hey guys, I really appreciate the feedback.
Rudedog your method sounds easiest. But I wonder, wouldn't that be kind of hard of the fuel pump?
Old Aug 12, 2009 | 07:43 PM
Won't be hard on the pump until it runs dry...... then you have a problem.
Simplest way is to push a hose down the fill pipe and siphon it out. I've done that several times on my 94.
Old Aug 27, 2009 | 07:55 PM
Z28WannaB's Avatar
I think there is an anti-siphon in the fill pipe. I tried to stick a hose down there once and it wouldn't go all the way to the tank.
Old Aug 27, 2009 | 11:40 PM
Not easy, but it worked on mine. Hose went right to the bottom of the tank.
Old Aug 28, 2009 | 11:01 AM
rclearyiii's Avatar
Same Here
Hose went to the bottom of my tank as well...
Old Sep 1, 2009 | 12:31 PM
Kevin Blown 95 TA's Avatar
I've tried a few times with a small hose and wasn't able to get it to go in there.
Old Sep 1, 2009 | 05:13 PM
Spartan7's Avatar
Try using a stiffer hose. I used the same method above to siphon all the gas out before I dropped the tank and it worked just fine.
Apr 24, 2015 01:03 PM
ad356
Apr 16, 2015 05:38 PM
2001CamaroGuy
Apr 5, 2006 10:56 PM
guionM
9
Aug 29, 2002 01:48 PM
guionM
18
Jul 11, 2002 01:45 AM
