Door removal and replacement/install?
Old May 15, 2006 | 06:28 PM
zbomb5610's Avatar
Did a search for door install or door removal, but didn't find anything.
Just wondering what the easiest way is to remove the doors and then replace them.
Is it pretty easy and straightforward? I will have to do this when i get the car back in a few days.
thanks
Zeeshan
Old May 15, 2006 | 11:53 PM
zbomb5610's Avatar
Re: Door removal and replacement/install?
found an old post
http://web.camaross.com/forums/showt...highlight=door
so hopefully that will help, seems pretty straightforward and i did the 98-02 front end conversion, so hopefully that gives a little experience in aligning the stuff.
Old May 16, 2006 | 12:27 AM
MyShibbyZ28's Avatar
I replaced my driver door, and it is very straight forward. Just take all the wiring out of the door first, or atleast get it started. Then start unbolting it. If you need to keep the same door I suggest getting a jackstand underneath the door so it doesn't slam to the ground. Once it's unbolted take the rest of the wiring out, and presto! It just takes a while to unbolt/rebolt the door since it is in a hard to reach spot. Aligning the door isn't so hard. I drew a line with a pencil where the hinge and fender meet so I could keep some kind of reference. It took me about 3 or so hours total to get the old door off and the new one on.
Old May 16, 2006 | 03:25 PM
zbomb5610's Avatar
thanks for the reply. I just picked up two complete doors and should be putting them on this weekend.
ill try to keep as many reference markers as i can for alignment.
DirtyDaveW
Dec 1, 2016 05:37 PM
Heathen1
Jan 2, 2016 04:27 PM
R@mpage
Apr 20, 2015 10:02 AM
sscott
Jan 17, 2015 04:30 PM
centric
Aug 15, 2002 09:04 PM
