Door Hinges
Old Jun 12, 2004 | 05:58 PM
$hawn's Avatar
Door Hinges
Are the factory door hinges welded to the door? Or are they bolted on? Or maybe both? My driver side door is sagging and I need to replace them. Would there be any other specail tools needed? Thanks.
Old Jun 12, 2004 | 11:25 PM
PDCamaro318's Avatar
I believe they are bolted on. I may be wrong. Shoebox if you could chime in that would be great.
Old Jun 14, 2004 | 10:02 PM
$hawn's Avatar
Theres obviously 3 nuts and studs on them, i'm guessing the hinges slid over the studs, and should be able to come off failry easy, i'm wondering if I should replace both or just the lower one?
Old Jun 15, 2004 | 08:17 AM
Unless you can tell that there is a lot of slop in your hinges, you might just need to hinge to door adjustment. The hinges just bolt on.
Old Jun 15, 2004 | 08:43 PM
$hawn's Avatar
Yeah I think at least one of them has some slop, proabaly the lower? Starting to rub on that plastic peice, and I'v already tryed to adjust the door, cant get it to move up very much, at least not enough to make a difference. Thanks guys.
Aaront810
Aug 29, 2020 09:34 PM
2QUIK6
Sep 17, 2016 02:31 PM
RUENUF
Mar 13, 2016 03:37 PM
IndyZman
Oct 22, 2015 02:17 PM
z28cam1993
Sep 9, 2015 04:08 AM
