Key Fob Question
Key Fob Question
I remember there being something about programming the key fob so that it does different things. Id like to program mine so it doesnt honk the horn all the time. I cant seem to find the article...anybody have a link or info?
Page 2-18 in your owners manual.
https://www.mygmlink.com/pdf/go2cont...99firebird.pdf
Feature Customization (If Equipped)
Your vehicle’s locks and lighting systems can be
programmed with several different features. The
features you can program depend upon the options that
came with your vehicle. The following list tells you the
features that can be programmed. Listed next to each
feature is the option you need to have on your vehicle in
order to be able to program that particular feature.
Exit Lighting (available for all)
Delayed Illumination (available for all)
Last Door Closed Locking (if equipped with power
door locks)
Lockout Prevention (if equipped with power door locks)
Remote Keyless Entry Verification (if equipped with
Content Theft-Deterrent System)
Theft-Deterrent Arming Method (if equipped with
Theft-Deterrent Arming Verification (if equipped
with Content Theft-Deterrent System)
Driver’s Door Alarm Delay (if equipped with
Shock Sensor Enable (if equipped with Content
Entering Programming Mode
To program features, your vehicle must be in the
programming mode. Follow these steps:
1. Put your key in the ignition.
2. Turn the ignition to RUN to disarm the Content
Theft-Deterrent System.
3. Turn the ignition to OFF.
4. Remove the RADIO fuse. This fuse is in the main
fuse block, located on the left side of your
instrument panel. See “Fuses and Circuit Breakers”
in the Index.
5. Turn the ignition to ACC.
You should hear a chime to verify that the system is
in the programming mode. If the chime sounds once,
you will be able to program Exit Lighting, Delayed
Illumination, Last Door Closed Locking and Lockout
Prevention only. If the chime sounds twice and your
vehicle is equipped with the Content Theft-Deterrent
System, you will also be able to program Remote
Keyless Entry Verification, Arming Method,
Arming Verification, Driver’s Door Delay and
Shock Sensor Enable.
yellowblue
2-19
Exit Lighting and Delayed Illumination
With Exit Lighting, your interior lamps will come on
for up to 25 seconds when the key is removed from
the ignition.
With Delayed Illumination, your interior lamps will come
on and stay on for up to 25 seconds when entering your
vehicle and up to 5 seconds when leaving your vehicle.
Your vehicle comes with both features enabled
(Mode 4). To change the factory setting, do
the following:
1. Turn the courtesy lamps on by turning the instrument
panel brightness control **** all the way up.
2. Count the number of chimes you hear. The number of
chimes tells you which mode your vehicle is set for.
3. Turn the courtesy lamp switch off.
4. Turn the courtesy lamp switch from on to off until
you hear the number of chimes that correspond to the
mode selection you want.
Mode 1: Both Off
Mode 2: Delayed Illumination Only
Mode 3: Exit Lighting Only
Mode 4: Both On
Last Door Closed Locking and Lockout Prevention
Your vehicle comes with this feature set in Mode 2.
To change the factory setting, do the following:
1. Press the LOCK switch on the door.
3. Press the LOCK switch on the door until you hear
the number of chimes that correspond to the mode
selection you want.
These features are designed to help prevent your keys
from being locked in your vehicle.
Mode 1: Both Off (Doors will lock and unlock when
you press the power door lock switch.)
Mode 2: Lockout Prevention Only (If you leave your
keys in the ignition and leave through the driver’s door,
you won’t be able to lock the doors with the power door
lock switch.)
Mode 3: Last Door Closed Locking Only (If the power
door lock switch is used to lock the vehicle while any
door is open, you will hear three chimes. The doors will
not lock until after all doors are closed.)
Mode 4: Both On (This combines Mode 2 and 3.)
yellowblue
2-20
Your vehicle comes with this feature set in Mode 5.
1. Press the UNLOCK button on the remote keyless
entry transmitter.
3. Press the UNLOCK button on the remote keyless entry
transmitter until you hear the number of chimes that
corresponds to the mode selection you want.
This feature provides feedback when the vehicle receives a
command from the remote keyless entry transmitter.
Mode 1: All Off (The headlamps will not flash and the
horn will not sound to provide you feedback that a
lock/unlock command has been received by the remote
keyless entry transmitter.)
Mode 2: Horn and Lamps/Lamps (Your horn will sound
briefly and your parking lamps will flash when you press
LOCK on the remote keyless entry transmitter. Only your
parking lamps will flash when you press UNLOCK.)
Mode 3: Horn and Lamps (Your horn will sound briefly
and your parking lamps will flash every time you press
LOCK or UNLOCK.)
Mode 4: Lamps (Your parking lamps will flash every
time you press LOCK or UNLOCK.)
Mode 5: Lamps/Horn and Lamps/Lamps (Your lamps will
flash upon the first press on LOCK, your lamps will flash
and your horn will sound upon the second press on LOCK
and your lamps will flash upon any press on UNLOCK.)
Your vehicle comes with this feature set in Mode 3.
1. Press the LOCK button on the remote keyless
entry transmitter.
3. Press the LOCK button on the remote keyless entry
Mode 1: All Off (No horn chirps or parking lamp flash.)
Mode 2: Horn and Lamps (Your parking lamps will
flash and your horn will chirp twice to verify the system
is armed using any arming method.)
yellowblue
2-21
Mode 3: Horn and Lamps/Lamps (If you use the remote
keyless entry transmitter to arm the system, your
parking lamps will flash and your horn will chirp twice
to verify that the system is armed. If it only chirps once,
the hatch is open or unlatched. If you use either the
power door lock switch or passive arming, only your
lamps will flash for verification.)
Mode 4: Lamps (When your vehicle arms, only your
parking lamps will flash for verification.)
1. Press the UNLOCK switch on the door.
3. Press the UNLOCK switch on the door until you
Mode 1: Alarm System Off (The system will not arm.)
Mode 2: Remote Keyless Entry Transmitter Lock
(When you lock your doors using the remote keyless
entry transmitter, the system will arm itself.)
Mode 3:Remote Keyless Entry Transmitter/Power Door
Lock Switch (If you use either the remote keyless entry
transmitter or the power door lock switch to lock the
doors, the system will arm itself.)
Mode 4: Passive Arming and Remote Keyless Entry
Transmitter/Power Door Lock Switch Arming (The
system will arm itself after all doors are closed plus
arming per Mode 3).
Driver’s Door Alarm Delay and Shock Sensor Enable
Your vehicle comes with this feature set in Mode 4.
1. Turn the parking lamps on and off.
3. Turn the parking lamps on and off until you hear the
number of chimes that corresponds to the mode
selection you want.
Mode 1: Zero Delay and Shock Sensor Disabled (The
alarm will sound immediately if the driver’s door is
opened with your key and the shock sensor will not be
available to measure sharp blows to your vehicle.)
yellowblue
2-22
Mode 2: Eight-Second Delay and Shock Sensor
Disabled (The alarm will sound eight seconds after the
driver’s door is opened with your key and the shock
sensor will not be available to measure sharp blows to
your vehicle.)
Mode 3: Zero Delay and Shock Sensor Enabled (The
alarm will sound immediately after the driver’s door is
opened with your key and the shock sensor will be
Mode 4: Eight-Second Delay and Shock Sensor Enabled
(The alarm will sound eight seconds after the driver’s door
is opened with your key and the shock sensor will be
Leaving Programming Mode
When programming is done, turn the ignition to OFF
and replace the RADIO fuse.
door locks)
in the Index.
yellowblue
2-19
the ignition.
the following:
Mode 1: Both Off
Mode 4: Both On
selection you want.
lock switch.)
yellowblue
2-20
entry transmitter.
LOCK or UNLOCK.)
entry transmitter.
yellowblue
2-21
arming per Mode 3).
selection you want.
yellowblue
2-22
your vehicle.)
guionM
18
Jul 11, 2002 01:45 AM
