does anyone on here use a pushbutton to start their fbody?
Old Oct 14, 2004 | 11:25 PM
Donohue96M6Z28's Avatar
my starter isnt getting any pwr, so im thinking about putting a push button in it to start it, if anyone on here has done it, where did u put the button at? and do u think it brings the value of the car down? should i try to stay away from doing this? thanks guys
Old Oct 14, 2004 | 11:53 PM
Bryan Smith's Avatar
Re: does anyone on here use a pushbutton to start their fbody?
if you're going to, definatly wire up a kill switch. I had one on my 94 z, they wired it in when they installed the alarm. They removed the cig lighter and put it there. It worked out pretty good.
Old Oct 15, 2004 | 12:19 AM
raul.garcia's Avatar
Will the car start if you supply the pwr? If the car doesn't start have you checked fuses, and fusible links?
Not a good thing to do on a 96'. Most likely you have anti-theft which is notorious for killing the ignition/starting systems when the key/cylinder, and anti-theft module don't communicate properly.
I would:
1.) Use a remote starter switch to crank it, if it starts the problem is in the wiring, and or fusible links ...etc between the starter and the ignition switch.
2.) if the car just cranks then, if you don't have quick access to the Throttle body pour a primer shot of gasoline through any hose connected to the intake, you may have to do this more than once, if it still doesn't start I'd suspect the anti-theft module is killing the starter, and injectors.
Old Oct 15, 2004 | 10:32 AM
ya the car does start when i supply the power, i bypass everything and just run a wire from the starter all the way up to the top of the eng compartment, and it doenst try to turn over if i try to start it regular, it does nothing, thanks guys for the input
Old Oct 15, 2004 | 03:37 PM
TraceZ's Avatar
Given this info, my guess is that the problem is the ignition switch located down low on the steering column. Try jumping the "start" wire on the switch and see if it cranks. If it does, replace the switch.
Old Oct 15, 2004 | 06:30 PM
Red96Lt1's Avatar
I would:
A remote start will not start the car unless you have bypassed the anti theft system. ie, the key must be present in the ignition, or a resistor of the exact same resistance in your key can be wire in the car.
meissen
Jun 1, 2015 07:59 AM
DirtyDaveW
Mar 15, 2015 07:01 PM
Gtpguy
Jan 26, 2015 04:50 PM
George 30th Aniv SS Conv
Sep 6, 2002 11:01 PM
FASTFATBOY
Jun 20, 2002 11:27 AM
