Disconnecting steering column for driver headers.
Old Aug 25, 2004 | 10:59 AM
NewbieWar's Avatar
well i cant seem to find anything on how to do this
so could someone walk me thro it?
Old Aug 25, 2004 | 02:26 PM
Mtrhds94Z's Avatar
Re: Disconnecting steering column for driver headers.
Each end of the shaft has a couplings that has a 'pinch bolt'...
Loosen those bolts, slide the shaft up farther onto the 'upper steering column shaft', then remove the lower end from the 'steering box'..
Then take the upper part off by sliding back down the steering column shaft part..
Old Aug 25, 2004 | 08:26 PM
Bud M's Avatar
I did it in the other direction. Getting it back together wasn't easy. Wish I had known!
Old Aug 25, 2004 | 08:49 PM
NewbieWar's Avatar
mine doesnt budge i tookout the bolt in the column and the one a ways lower but nothing wants to move
Old Aug 25, 2004 | 09:08 PM
carlos64030's Avatar
You gotta smack on the upper edge of it with a hammer.
Old Aug 25, 2004 | 09:32 PM
TechCam97's Avatar
Well, yea, it's a 94. It's going to probably need some convincing with a hammer. I just used a rubber mallet and knocked it loose with that. It seems like it's more of a chore than it really is, lol. Don't worry, it'll come off.
Old Aug 26, 2004 | 12:10 AM
Bud M's Avatar
WD40 may help loosen it up
Old Aug 28, 2004 | 08:46 PM
NewbieWar's Avatar
ok i got it off it worked and everything.. i couldnt get the botom to budge so i just took off the top, but anywho... how do i get it back on?
Old Aug 30, 2004 | 02:05 AM
Skull Leader's Avatar
Arrow Re: Disconnecting steering column for driver headers.
I took it off the other day for the rag joint replacement (EXCELLENT). It took me the better part of 2 hours to get it off (demonically posessed). Took me all of 3 minutes to get it back on. I stuck a long, tough screwdriver into the oval hole at an angle, and used it to hammer it back in.
I don't know how hammering it off is done. I can't generate enough momentum between the shaft and firewall. Only a very small Bruce Lee could use a 1" punch down there.
Old Aug 31, 2004 | 11:22 PM
Bud M's Avatar
Getting it back on was the hard part for me. More specifically, getting it lined up right so it could be hammered back on. I ended up having to grine on the clamp a bit to get it started back onto the shaft. Once I got it started, it was not difficult.
Victor Lamb
Aug 26, 2017 02:52 PM
nikko
Apr 28, 2015 10:05 AM
mspennyhughes
Mar 1, 2015 03:50 PM
BIGCOWL-IMP
Nov 21, 2014 09:40 AM
Jul 4, 2005 05:00 PM
