Dimmer Switch
Old Oct 6, 2005 | 12:52 PM
StevenSimpson's Avatar
Dimmer Switch
I tried searching for this and I didn't see what I was looking for...My brights have suddenly decided to turn on by themselves along with the dims. I tried turning them off, but I cant, there is not a clicking noise, so I figured it was the dimmer switch. Now to my question, Is there anyway to swap out the dimmer switch without tearing the steering column completely apart?
Old Oct 7, 2005 | 01:25 AM
Re: Dimmer Switch
Ttt
Old Oct 7, 2005 | 02:20 PM
mr_camaro96z28's Avatar
Re: Dimmer Switch
Yeah the dimmer switch isn't actually in the column its at the base of it right above the brake pedal. There's a rod that runs down from the turn signal lever to the dimmer switch. If there's no click the rod might have come out.
Old Oct 8, 2005 | 01:02 PM
TraceZ's Avatar
Re: Dimmer Switch
I agree that the actuator rod is likely the problem. It has either come out as mentioned above, or it needs to be bent a little to work right. In any event, it looks like you'll need to get under the dash and look at the way the rod is seated in the dimmer switch.
Old Oct 10, 2005 | 02:45 PM
Re: Dimmer Switch
Thanks! I had to disconnect my bright bulbs... hopefully this will fix the problem!
Ericksd
Jan 20, 2016 06:07 PM
IndyZman
Oct 22, 2015 02:17 PM
94Z28LS1toLT1
Sep 22, 2015 05:24 PM
Rod Bender
25
Sep 16, 2015 01:47 PM
jackpawt883
Sep 10, 2015 08:53 PM
