coolant temp
Old Apr 21, 2015 | 04:28 PM
  #46
warmeck's Avatar
Re: coolant temp
it did say some of those codes were for the 3.8l model
Old Apr 21, 2015 | 04:29 PM
  #47
Re: coolant temp
I'm going to tell you this once... you do not have those codes. We have seen people post that exact same code list over and over, and tracked them back to the Innova 3120.
Old Apr 21, 2015 | 04:30 PM
  #48
warmeck's Avatar
Re: coolant temp
ok and i have the 3140d. so shoudl i connect the scanner and erase these codes? what am i to do?
Old Apr 21, 2015 | 04:44 PM
  #49
warmeck's Avatar
Re: coolant temp
well the innova unit came with a usb and some cables that hooked up to the obd2 connector can i cut the cable and usb and use gary scanner? ima upload pictures in a second
Old Apr 21, 2015 | 04:55 PM
  #50
warmeck's Avatar
Re: coolant temp
Cut where these red marks are and make an connector?Name:  IMG_20150421_17452_edit_1429652732313_zps00qb8fpl.jpg
Size:  209.3 KBName:  IMG_20150421_17460_edit_1429652793670_zpsimzfrk9b.jpg
Old Apr 21, 2015 | 05:01 PM
  #51
Re: coolant temp
Since you DO NOT HAVE THOSE CODES, you don't have to "erase" them. They are FIGMENTS OF THE SCANNER'S IMAGINATION.
Old Apr 21, 2015 | 05:02 PM
  #52
warmeck's Avatar
Re: coolant temp
i get tht this scanner wont work. can i cut these cables and make the same cable?? so can connect to this scan9495
Old Apr 21, 2015 | 09:53 PM
  #53
Re: coolant temp
You cannot hack that cable to work.
Return the scanner. You were pre-warned about the Innova.
Go to the computer forum.
Get information about the cable you need and purchase or make one.
Get scan9495 sofware.
Scan your car.
Old Apr 22, 2015 | 06:45 AM
  #54
Re: coolant temp
I see GaryDoug is helping you on the "Computer..." forum post. He has basically posted that there are two ready-made cables that are known to work, and that the cables made with unreliable Chinese components are no longer a good idea.
I've seen people post that they were able to get the ALDLCable and RedDevilRiver cables delivered overnight.
Old Apr 22, 2015 | 08:53 PM
  #55
Biggiebound's Avatar
Re: coolant temp
i might of installed the wrong thermostat what do u guys think?? left is new right is old.
The one on the left is the correct thermostat. The one on the right is for the old SBC 1st generation. I just went through this.
Old Apr 27, 2015 | 02:27 PM
  #56
warmeck's Avatar
Re: coolant temp
ok i got codes DTC 70: engine coolant temperature sensor circut short and DTC 15: a/c clutch relay driver circuit.
Old Apr 27, 2015 | 04:06 PM
  #57
Re: coolant temp
Backwards.
DTC 15 = Engine Coolant Temperature (ECT) Sensor Circuit (signal voltage high, low temperature indicated)
That's most likely an open circuit. If you pull the harness connector off the sensor, and measure the voltage between the two wires in the connector, do you have 5V?
Test methods, per Shoebox:
4th Gen LT1 F-body Tech Articles
DTC 70 = A/C clutch relay driver circuit
Does the A/C clutch kick on when you turn on the A/C?
Old Apr 27, 2015 | 04:34 PM
  #58
warmeck's Avatar
Re: coolant temp
Backwards.
your right my crimping sucks and it was an open circuit bought some new wires and re did the crimp and it starts up first crank purrin. and i toko out my a/c relay so that is probably why its giving me that? but when i turn my a/c on somethign does click. just bought a new a/c compressor relay hopefully that fixed the problem. probably should replace the air pump relay as well?
Formula Steve
Sep 19, 2023 08:31 AM
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
Bigtoyz97
Sep 21, 2015 01:44 PM
plattted
9
Sep 20, 2015 11:23 AM
