Coolant passage question
Old Dec 7, 2020 | 12:02 PM
Cameron13588's Avatar
Coolant temp sensor
this is a 97 lt1 out of a firebird with a t56. Im swapping into a 83 RX-7. I seen a video somewhere that this plug in the passenger side head between cylinders 6-8 is a coolant passage that i can use for a coolant temp sensor gauge. Hoping for someone to confirm this. Also sorry if this is a topic thats alread been brought up, i did some research but couldnt find much else other then the video i seen. Thanks in advance
Old Dec 7, 2020 | 01:45 PM
Re: Coolant passage question
That location works for a coolant temp sensor.
The stock location for the gauge coolant temp sensor is in the driver side head, between #1 and #3. Since the exact same head is used on both banks of the engine, when the head is on the passenger side, the hole ends up between #6 and #8, and they put that plug in it.
The coolant temp sensor that feeds the PCM is located in the lower part of the water pump housing.
Old Dec 7, 2020 | 01:51 PM
Stock setup, courtesy of Shoebox. If you haven’t been to the Shoebox site, it is the best resource on the internet for information on the LT1 engine.
http://shbox.com/1/temp_sensor2.jpg
http://shbox.com/1/temp_sensor1.jpg
4th Gen LT1 F-Body Tech Aids
Old Dec 7, 2020 | 01:55 PM
Thanks a ton for the info!
warmeck
Apr 27, 2015 04:34 PM
97firebird
Aug 15, 2004 09:09 AM
djc485
Apr 1, 2004 12:38 AM
Liquid Teal
Feb 27, 2004 05:05 PM
