computer
Old Aug 27, 2014 | 06:29 PM
daewokr's Avatar
computer
is it true the 98 computer has problems reading certain cams if the lsa is above 110
Old Aug 28, 2014 | 06:56 AM
Re: computer
The PCM doesn't "read" the cam. It has to be tuned for the cam. Where you would probably get into a problem would be the misfire detection, where the PCM might have a problem with the "crank relearn" that helps it determine when a misfire is occurring.
See this writeup:
Crankshaft Position Sensor Learn Issues on Gen III Engines
Old Aug 29, 2014 | 07:06 PM
daewokr's Avatar
Re: computer
is it true a 2002 pcm will solve the cam issue? and if so where would I get one?
frankrizz
Sep 23, 2015 04:33 PM
frankrizz
Sep 23, 2015 04:21 PM
fireside286
Sep 15, 2015 10:11 PM
350350
14
Aug 11, 2015 12:03 PM
