Car won't start
Old Sep 2, 2004 | 02:28 PM
BiGGinZ's Avatar
Car won't start
I took my old alarm out and then when I tried to start my car there was no electricity. No acc. turned on, nothing. So I jumped the battery hoping it was dead and still no acc. need help asap.
Old Sep 2, 2004 | 03:30 PM
BiGGinZ's Avatar
Re: Car won't start
Guys I need help it is like my car has 0 power from the battery. Need help ASAP!
Old Sep 2, 2004 | 03:45 PM
TraceZ's Avatar
Re: Car won't start
I know some alarms interrupt the coil or starter, but I've never heard of an alarm cutting power to the entire car!
I'm guessing you have a problem other than the alarm, or maybe during its removal you accidentally screwed up a connection?
Start by cleaning both the battery cables. Use a test light at the fuse panel to make sure it is getting power.
Do you own a test light?
Old Sep 2, 2004 | 03:50 PM
BiGGinZ's Avatar
Re: Car won't start
No I don't have a test light. But my battery was working, then when I took my alarm out then no power. Is there anything I could have unhooked? It happend after I unhooked the siren so I wasn't even unhooking things under the steering column yet.
Old Sep 2, 2004 | 05:20 PM
BiGGinZ's Avatar
Re: Car won't start
Still need help guys.
Old Sep 2, 2004 | 06:07 PM
BiGGinZ's Avatar
Re: Car won't start
Help ASAP!
Old Sep 2, 2004 | 06:38 PM
TraceZ's Avatar
Re: Car won't start
Originally Posted by BiGGinZ
Help ASAP!
There is not much we can do to help until you get a test light and see if there is power at the fuse boxes.
Have you checked the battery cables? It is very odd for a car to be completely dead if the battery is charged and has good cables on it.
I am going under the impression not even the brake lights, dome lights, guages or headlights work.
Old Sep 2, 2004 | 06:39 PM
BiGGinZ's Avatar
Re: Car won't start
Yep nothing is working.
Old Sep 2, 2004 | 06:56 PM
TraceZ's Avatar
Re: Car won't start
If nothing works, that means the fuse boxes are not getting power. I really think the problem is either the battery or the cables.
The headlights should at least work. Let us know what you find out with some testing.
Old Sep 2, 2004 | 09:03 PM
BiGGinZ's Avatar
Re: Car won't start
I worked on it and got a new battery just in case and cleaned the cables and everything around the battery and it works now, thanks for your help.
Old Sep 3, 2004 | 07:21 AM
TraceZ's Avatar
Re: Car won't start
I'm glad it's up and running agian!
Britbilly
Jan 7, 2015 08:49 PM
Dec 4, 2014 11:56 AM
Dyoung_Z28
Nov 25, 2014 05:26 PM
USAirman93
Nov 24, 2014 03:37 PM
lbrowne
Nov 13, 2011 04:25 PM
