Car won't start
I took my old alarm out and then when I tried to start my car there was no electricity. No acc. turned on, nothing. So I jumped the battery hoping it was dead and still no acc. need help asap.
Re: Car won't start
Guys I need help it is like my car has 0 power from the battery. Need help ASAP!
Re: Car won't start
I know some alarms interrupt the coil or starter, but I've never heard of an alarm cutting power to the entire car!
I'm guessing you have a problem other than the alarm, or maybe during its removal you accidentally screwed up a connection? Start by cleaning both the battery cables. Use a test light at the fuse panel to make sure it is getting power. Do you own a test light? |
Re: Car won't start
No I don't have a test light. But my battery was working, then when I took my alarm out then no power. Is there anything I could have unhooked? It happend after I unhooked the siren so I wasn't even unhooking things under the steering column yet.
Re: Car won't start
Still need help guys.
Re: Car won't start
Help ASAP!
Re: Car won't start
Originally Posted by BiGGinZ
Help ASAP!
There is not much we can do to help until you get a test light and see if there is power at the fuse boxes. Have you checked the battery cables? It is very odd for a car to be completely dead if the battery is charged and has good cables on it. I am going under the impression not even the brake lights, dome lights, guages or headlights work. |
Re: Car won't start
Re: Car won't start
Yep nothing is working.
The headlights should at least work. Let us know what you find out with some testing. |
Re: Car won't start
I worked on it and got a new battery just in case and cleaned the cables and everything around the battery and it works now, thanks for your help.
Re: Car won't start
