Car overheating
Old Apr 10, 2011 | 06:13 PM
Chase8808's Avatar
Car overheating
This is my first time usingthis forum. I just got a 1997 camaro z28. When I got it it needed a radiator. It wasn't a bad leak so I drove it from point A to B stopping every once in a while to put water in it before it got to hot. Anyway it ran about 190 the whole way back. I put a new radiator and thermostat in it before driving. Now my car is running just about 210 and almost at the third mark on the temp gauge. It goes up to almost the third mark and the fans cut on and it goes back down to 210. It does that the entire time I am driving the car. Does anyone know what this could be?
Old Apr 10, 2011 | 06:22 PM
moparman's Avatar
Re: Car overheating
Did you bleed the air out of the system?
Old Apr 10, 2011 | 06:29 PM
Chase8808's Avatar
Re: Car overheating
When i bleed the coolant does the car need to be running or off?
Old Apr 10, 2011 | 08:49 PM
moparman's Avatar
Re: Car overheating
Running.
Is the front air dam still on the car?
Old Apr 10, 2011 | 10:56 PM
Re: Car overheating
Read the last bullet under "Refill".
http://shbox.com/1/4th_gen_tech2.html#radflush
With a stock thermostat, the coolant is supposed to run at the 210*F midpoint of the temperature gauge.
Old Apr 11, 2011 | 06:34 AM
moparman's Avatar
Re: Car overheating
In slow city driving, with a stock cooling system, the temp will probably be right in the middle of the gauge, and may be slightly past it. When you stop in traffic, say for a traffic light, it is normal for the the temp to creep up close to the third hash mark, then go down when the fans come on. During highway driving, the temp will probably be to the left of the middle hash mark.
Old May 6, 2011 | 03:24 PM
Chase8808's Avatar
Re: Car overheating
I tried bleeding the coolant system. I thought it might have been my fans not cutting on so hot wired the fan to maually cut on. I replaced the thermostat and radiator cap. Now what it is doing is running halfway between the 210 and third mark on my guage. But when I stop at a stop light or sign it goes down to 210 and stays there. The guy who had it before me put stop leak in it because the radiator was cracked. I was wondering if maybe it is clogged up in there if that is even a possibility. Please someone help I am currently trying to sell it for 2500 dollars just because i dont know what it is but I really don't want to
Old May 6, 2011 | 03:26 PM
Chase8808's Avatar
Re: Car overheating
and it does not have the front air dam on the car. wasn't there when I bought it.
Old May 6, 2011 | 04:06 PM
rngilliland's Avatar
Re: Car overheating
The missing air dam is why it heats up when you are driving and then cools down when you stop. Did you use the LT1 thermostat or a regular thermostat. The LT1 thermostat is different.
Old May 6, 2011 | 06:36 PM
moparman's Avatar
Re: Car overheating
Yes, the front air dam needs to be replaced.
Jazsun
Dec 29, 2014 12:14 PM
1996LT1Z28
Middle Atlantic
Dec 4, 2014 09:37 PM
1996LT1Z28
Dec 4, 2014 09:20 PM
USAirman93
Nov 24, 2014 03:37 PM
