Blinker doesn't blink... indicator stays on.
Old May 2, 2011 | 06:58 PM
browenb's Avatar
Ok folks, Right hand indicator works fine.
Hazzard lights work fine.
Left indicator on the dash cluster stays on, and does not blink.
Any thoughts?
Old May 4, 2011 | 01:40 AM
L.dookie's Avatar
Re: Blinker doesn't blink... indicator stays on.
blown bulb on either left front or rear turn signal.
Old May 4, 2011 | 07:31 AM
87DJP2001's Avatar
Replace blinker module under dash...Less than $4.00 at any AutoParts store..
Old May 4, 2011 | 07:56 AM
km9v's Avatar
Bulb.
Old May 4, 2011 | 07:58 AM
93midnightta's Avatar
If the bulb and the module don't work then it's the actual bulb sockets. I had the same issue on my TA way back when and the only thing that fixed it was replacing the brake light bulb sockets. It was a fairly common issue.
Old May 5, 2011 | 02:02 PM
Ryan96WS6's Avatar
Just fixed mine with the same problem. It was an intermittent issue. The fix was a new socket also.
Old May 5, 2011 | 02:05 PM
Klypto's Avatar
Replacing the bulb fixed it for me before...
Sent from my Xoom using Tapatalk
Old May 7, 2011 | 01:22 PM
malachi85's Avatar
Pull the bulb turn it 180* and put it back in...I do that everytime I get into that rut.
Magenta_Hearts
Mar 29, 2017 08:54 PM
timmy39120
May 8, 2015 11:41 AM
jj_burchiel
Mar 21, 2015 12:51 AM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
