can some one explain and show me how my radiator gets mounted?
Old May 25, 2012 | 10:41 PM
coreylt1's Avatar
i just put my motor in today and just trying to piece the rest together , i dont understand how the radiator get mounted up, i know on my other cars there is rubber grommets on the bottom that pop in the mount and just bolts up top..pictures would be greatly appreciated
Old May 25, 2012 | 10:54 PM
Dave89IROC's Avatar
In a 4th gen, its held in by the plastic shrouds
Old May 25, 2012 | 11:05 PM
coreylt1's Avatar
Re: can some one explain and show me how my radiator gets mounted?
it snaps into something?
Old May 25, 2012 | 11:14 PM
Dave89IROC's Avatar
Pretty much, I'll see if I can find an exploded view in the morning
Old May 26, 2012 | 05:57 AM
mab6680's Avatar
the radiator has 4 tabs that stick out 2 on each side the support has 4 hooks (best way i can describe) 2 on each side you have to lift the radiator up above the hooks then slide it back down on the hooks on the support
Old May 26, 2012 | 10:34 AM
You can always check Shoebox for info like this:
http://shbox.com/1/radiator_mounting.jpg
You should add a "Signature" with basic info about your car - year, model, engine, trans and any major mods. I think we are all assuming from your screen name that you have a 93-97 LT1.
Old May 27, 2012 | 08:11 AM
coreylt1's Avatar
i saw that diagram of it but i still dont understand, i really need a picture or 2 of how it sits and what it slides into
Old May 27, 2012 | 09:46 AM
Here'a link to the 94 factory manual. Should be about the same for your 96, with regard to the radiator.:
Free Cloud Storage - MediaFire
Double click on a filename to start the download for that file.This site has a good amount of ads and some popups, but doesn't require you to install anything, just click on the "close" or "X" of each unwanted popup. Pay attention to not click to close the file download popup message. After the file download, close the browser download page to start on the next file. The files are pure pdf with no added items.
Go to page 6B-20 in Volume 1 of 2, Part 1 of 2.
Old May 27, 2012 | 03:44 PM
Once you look at the tabs on the radiator and slots on the car, you will see how it goes on. It always seems to be a bit of a struggle for me to get them all in at the same time.
Old May 27, 2012 | 04:53 PM
coreylt1's Avatar
i dont see any slots on my car, thats the problem lol. are the slots directly into the metal or is there suppose to be a plastic piece with the slots on it
Old May 28, 2012 | 07:07 PM
IIRC, the slots are on the mounting for the a/c condenser. If that is removed, you don't have a way to mount the radiator.
Old May 28, 2012 | 11:05 PM
coreylt1's Avatar
OHHHHH this makes perfect sense now.. thank you so much
DirtyDaveW
Dec 1, 2016 05:37 PM
Jun 6, 2015 08:27 AM
Magenta_Hearts
Mar 25, 2015 10:24 AM
4586
Parts Wanted
Mar 17, 2015 11:24 PM
silvermansteve
Mar 4, 2015 05:02 PM
