Camaro body work
Re: Camaro body work
The sail panel is the interior piece with the speaker grille beside the rear seat.
If you are referring to the exterior roof panel (assuming you mean exterior, because you say "body work"), it has to be cut off. The composite panel is glued with urethane adhesive to the metal roof structure.
Go to the top of the page and click on "User CP" on the drop down menu click on "Edit Signature". There you can add the year/make/model of your car and a short discription of any mods.
What's the problem? Why do you need to remove the roof panel?
The factory manual has drawings showing where to cut the roof to remove it without destroying any of the underlying structure (or you can make some trial cuts). Of course, the roof panel will be destroyed-there is no other way. I think a pneumatic cutting tool is normally used. You can generally find used manuals on Ebay or other online resellers of used manuals.
CARiD
Dec 26, 2014 04:20 AM
Jul 4, 2005 05:00 PM
