Camaro body work
Old Jan 11, 2011 | 12:39 AM
rusken73's Avatar
Camaro body work
Can anybody give any ideas on a good way to remove the sail panel?
Old Jan 11, 2011 | 05:08 AM
Re: Camaro body work
What year, model?
Old Jan 11, 2011 | 08:19 AM
rusken73's Avatar
It's a 99 Z28.
Old Jan 11, 2011 | 06:03 PM
And what part are you calling the "sail panel"? The roof?
Old Jan 11, 2011 | 11:56 PM
rusken73's Avatar
Yes the part between the t-top and the hatch.
Old Jan 12, 2011 | 07:52 AM
The sail panel is the interior piece with the speaker grille beside the rear seat.
If you are referring to the exterior roof panel (assuming you mean exterior, because you say "body work"), it has to be cut off. The composite panel is glued with urethane adhesive to the metal roof structure.
Old Jan 12, 2011 | 09:55 AM
rusken73's Avatar
Thank you for the help I think I'll find a way around it so it can stay on.
Old Jan 12, 2011 | 10:43 AM
Z28SORR's Avatar
Go to the top of the page and click on "User CP" on the drop down menu click on "Edit Signature". There you can add the year/make/model of your car and a short discription of any mods.
What's the problem? Why do you need to remove the roof panel?
Old Jan 12, 2011 | 11:13 AM
And of course the roof panel is different, depending on whether you have T-tops or not.
Old Jan 12, 2011 | 12:03 PM
rusken73's Avatar
My car is a 99 z28 it has t-tops. So u guys are sayin that the roof cover is glued on not bolted or anything?
Old Jan 12, 2011 | 05:08 PM
True statement.
Old Jan 12, 2011 | 06:22 PM
rusken73's Avatar
Ok what is a good way to remove that peice?
Old Jan 12, 2011 | 08:59 PM
The factory manual has drawings showing where to cut the roof to remove it without destroying any of the underlying structure (or you can make some trial cuts). Of course, the roof panel will be destroyed-there is no other way. I think a pneumatic cutting tool is normally used. You can generally find used manuals on Ebay or other online resellers of used manuals.
Old Jan 12, 2011 | 10:20 PM
rusken73's Avatar
Ok cool thank you for the help it gave me some good ideas. Thank you.
Red Hawk 94
Mar 18, 2019 04:03 PM
smokin25th
Jan 1, 2015 09:06 AM
CARiD
Dec 26, 2014 04:20 AM
Queens94z28
Dec 20, 2014 09:11 PM
Jul 4, 2005 05:00 PM
