C105, Pin F ?'s
C105, Pin F ?'s
C105, Pin E (misposted in title), the tan serial data signal, which component does it go to under the hood? Do I need it? Thanks in advance.
So on plug C220, pin F, on a 95', if it doesn't come from the DLC, goes to what device? According to the wiring diagram for the DLC, the serial comes from pin M on the DLC, goes through plug 220, pin F, then to the PCM. The diagram shows the seral for the EBTCM and SIR go through plug C200, pin A12. I guess I need the wiring diagram that might show pin E, on plug C105.
There seems to be a discrepancy or two on the diagrams. F on C220 is tapped into the same wire that is at E on C105. But, F on C220 shows to dead end at C220 on the DLC side.
(plus the diagram shows the EBCM to be on the engine compartment side of C200, but we know it is under the dash)
it eventually ends up at the pcm under the hood, if thats what you're asking. thats the communication bus for all the modules, and how you get codes from the pcm. might help if we knew what you were trying to accomplish here. that way we may be able to better assist you.
