A/C oil leak
Old May 28, 2010 | 05:20 PM
antman's Avatar
A/C oil leak
I have an oil leak dripping from the coolant hose running beneath the a/c compressor. I'm guessing its the a/c compressor that's leaking. If the compressor is leaking, can it be fixed or do I have to replace the compressor?
Old May 28, 2010 | 06:35 PM
Drew24's Avatar
So is it leaking oil? because that wouldn't be the ac compressor
Old May 28, 2010 | 07:12 PM
FastandBlue's Avatar
Yeah buddy, that's not good if what you're saying it true... Could you explain what exactly is "leaking." Is it black, like car oil?
Old May 28, 2010 | 09:26 PM
antman's Avatar
It's not black so I'm guessing it's not engine oil and it's too thick to be antifreeze.
Old May 29, 2010 | 07:21 AM
rngilliland's Avatar
Probably power steering fluid.
Old May 29, 2010 | 11:20 AM
Drew24's Avatar
What color is it?
Old May 29, 2010 | 01:05 PM
The A/C compressor is lubricated by a few ounces of oil mist that circulates with the refrigerant. Generally, when the system leaks, all you will see is an oily surface immediately at the leak, not "drops".
Old Jun 6, 2010 | 01:46 PM
white97T/A's Avatar
FWIW if the A/C compressor was leaking its oil, it would also be leaking freon and the A/C would not be blowing cold.
Old Jun 6, 2010 | 03:20 PM
BandDirector Blk98ZM6's Avatar
My AC compressor had been leaking oil, actual drops on the gound, for about the past 3 years...it still worked fine though, until this summer. It finally stopped blowing cold, so I had it replaced. Ran me $920!
However, the AC compressor will leak oil and still function...until it eventually runs out. There is no fix for it except to replace the compressor. However, in very rare instances, it will leak from one of the fittings going into the compressor and you can just have the fitting replaced, but more often than not, it's the actual compressor.
Magenta_Hearts
Mar 29, 2017 08:54 PM
surreybrad
Apr 22, 2015 06:40 AM
BigWil
Mar 29, 2015 12:24 PM
artic94
Jan 17, 2015 11:19 AM
